03-31-2010 03:58 AM - edited 07-03-2021 06:41 PM
my wlc analyzer keep on informing me about syslog messages sent in broadcast from my APs.
how can I solve this problem?
thanks
Johnny
Solved! Go to Solution.
03-31-2010 11:28 PM
by default, the LAPs send log infos to the broadcast address, 255.255.255.255. you should set this to your syslog-server, so that can be unicasted.
config ap syslog host global 1.2.3.4
otherwise your LAP-network will be flooded with broadcasts if something odd happens.
see also "Wireless LAN Controller (WLC) Configuration Best Practices" for details on this hint and other things that you possibly "should set".
03-31-2010 05:25 PM
I haven't heard of this before. Can you post the error message?
03-31-2010 11:28 PM
04-01-2010 06:14 AM
very good!
I tried to find a similar command on the GUI but I didn't find.
I thank you very much
Johnny
