WLC base license vs evolution licenses
Good afternoon,
one of my client I had ordered 100 adder license for his new setup.
current setup have only 40 license. now i want to use 20 more aps with his existing wlc 5508.
now my question is that, can i use my existing as well as evolution licenses for time being (e.g. 40+evolution) or  i can use only evolution for time being. after coming my new adder licenses, i can add my new ap license in WLC and  roll back as it is. or how it will act.
can you help me in that.
Nalin
VIP Purple
Hi Nalin,I don't think you
Hi Nalin,
I don't think you can use an evaluation to increase an existing license. Normally Evalaution are  for WLC's with zero AP license and that expire after 60 days.
Better to order adder licencse and then use other APs.
Check here: http://www.cisco.com/image/gif/paws/112926/5508-wlc-license.pdf
Hope it helps.
Dont forget to rate helpful posts
Silver
you can not use licensing
you can not use licensing this way either use the evaluation license for the time being and later add the licenses in the WLC
Thanks ..
Thanks ..
Please refer to the link for
Please refer to the link for difference between WLC base license vs evolution licenses-
104
