WLC cannot get IP of the Wireless Clients and client not able to ping to the gateway
Dear Cisco Expertise,
I have configured WLC embedded in Cisco C3650 switch and also 1 unit AP3702I. AP now able to join to the controller. My client able to connect to the AP and get the IP address (10.127.117.1) from the DHCP server but unable to ping to the gateway (10.127.117.254 - interface gateway). Both switch and AP able to ping to the interface gateway. I also trying to ping to the client from the switch and also from the AP to the client but not able to ping.
I've check via switch can see the client's IP address and MAC address (using ARP)
#sh arp vlan 77
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.127.117.1          0   843a.4b90.17e0  ARPA   Vlan77
Internet  10.127.117.254          -   3c08.f6b7.2173  ARPA   Vlan77
Need your expertise on this matter. Thank you.
Configuration as below:
Switch
ip dhcp pool LWAPP_VLAN
 network 10.127.117.0 255.255.255.0
 default-router 10.127.117.254
 dns-server 10.127.113.10
 domain-name xxx.com
vlan 77
 name LWAP_VLAN
interface Vlan10
 ip address 10.127.112.254 255.255.255.128
interface Vlan77
 ip address 10.127.117.254 255.255.255.0
 ip helper-address 10.127.117.254
interface GigabitEthernet3/0/5
 description Connect to AP Test
 switchport access vlan 10
 switchport mode access
 no logging event link-status
wireless mobility controller
wireless management interface Vlan10
wireless security web-auth retries 5
wireless mgmt-via-wireless
wlan APAC-WLAN 2 Wifi-Test
 client vlan LWAP_VLAN
 ip dhcp opt82
 ip dhcp opt82 ascii
 ip dhcp opt82 format add-ssid
 ip dhcp required
 ip dhcp server 10.127.117.254
 no security wpa akm dot1x
 security wpa akm psk set-key ascii 0 B*MY2014
 security wpa wpa2 ciphers tkip
 session-timeout 300
 no shutdown
ap group APGroup-Test
 description "For Testing Purposes"
 wlan APAC-WLAN
  vlan LWAP_VLAN
AP
interface Dot11Radio0
 antenna gain 0
 stbc
 mbssid
 power client local
 packet retries 64 drop-packet
 station-role root
interface Dot11Radio1
 antenna gain 0
 stbc
 mbssid
 power client local
 station-role root
interface GigabitEthernet0
 duplex auto
 speed auto
interface GigabitEthernet0.1
 encapsulation dot1Q 1 native
 bridge-group 1
 bridge-group 1 spanning-disabled
 no bridge-group 1 source-learning
interface BVI1
 mtu 1792
 ip address 10.127.112.202 255.255.255.128
interface Virtual-WLAN0
ip default-gateway 10.127.112.254
ip forward-protocol nd
ip dns server
Everyone's tags (1)
VIP Purple
Pls try the below SSID
Pls try the below SSID configuration. WPA2 to be configured with AES & not TKIP.
 security wpa
 security wpa wpa2 ciphers aes
 ip dhcp required
 no shutdown
This post should give you some help as well
http://mrncciew.com/2013/12/04/wlan-config-in-3850-part-1/
Rasika
**** Pls rate all useful responses ****
Hi Rasika
Hi Rasika
I also having the same problem like fadzin.
I have done what you suggest in this post, unfortunately i still couldn't ping the default gateway (vlan 103 interface) from my wireless client (vlan 103).
However, i have no issue to ping the vlan 103 interface from my 3650 switch.
I have also have checked the ACL configuration in switch but no luck.
Any ideas what could be the problem ?
Thank you.
BR
Adam
657
