Silver
WLC in HA mode
i have two WLC which is 5508 series.
I configured basic parameters and ensured its reach-ability. Then I configured the peer redudancy mgmt IP & redudancy mgmt IP. All 4 Ip are in same subnet
I issued below commands
config redudancy unit primary /secondary (respectively)
config redudancy mode sso on both
And the system rebooted itselg.
I checked the ports on core switch on which the WLC are connected and it is up and working
but the problem is i can reach only primary and not the secondary and the secondary i know theoretically reboots couple of times but it is not reachable
sh cdp nei shows WCO1 and WC02 but not WC01-standby.
Is this normal? how long will it take to get the HA back up? If not what do i need to do?
Posted by WebUser Shalini Menon from Cisco Support Community App
Silver
WLC in HA mode
sumne answer my question!!!!!!!! arghhh!
Bronze
WLC in HA mode
if you issue show redundancy summary on primary unit, what do you see? can you please post it here?
also, a good way to start troubleshooting is to follow this guide:
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bd3504.shtml
Hall of Fame Super Gold
WLC in HA mode
Post the output to the command "sh redun summary".  There's only ONE IP address which you can reach for the secondary controller and you'll find it in this command.  You won't be able to reach the secondary via HTML but telnet/ssh only.
Silver
WLC in HA mode
it shows peer state as unknown and local state as active
WLC in HA mode
I shall repeat what I posted previously, "POST the output".  If you don't want to provide us the info, then how can we help?
Silver
WLC in HA mode
ok someone from the team did erase d config...i saw the post the output message..doesn't mean you have to enter in CAPS.
220
