06-10-2008 12:19 AM - edited 07-03-2021 04:00 PM
Guys,
I know that there are very similar diagrams in the mobility guide on L3 roaming, but wanted to put a bit more text around each step and wanted you guys to check if it was correct of if I have got it completly wrong. It is just important to get this bit of the puzzle correct.
Please see the attached jpeg diagram, (can post in Visio if you prefer).
Have I got the text correct in regards to how this works. I am giving our support guys a heads up on this at some stage so would be good for some comments?
Kindest regards as always, and thx for all the help.
Ken
Solved! Go to Solution.
06-13-2008 04:26 AM
Here is a link regarding what you are looking for. Your diagram seems accurate though.
http://www.cisco.com/en/US/docs/wireless/controller/4.2/configuration/guide/c42mobil.html
06-13-2008 04:26 AM
06-16-2008 04:24 AM
that is the baby
many thx - Ken
06-16-2008 04:58 AM
No problem... Glad to help.
