WLC LAG to HP switch
I would like to connect my WLCs (5508) to HP Procurve switches.
Will I run into any problems if I choose to configure the WLC ports for LAG?
The 7.0 config guide talks about LAG as being a partial implementation of 802.1ad.
Also the guide only talks about connecting to a Catalyst.
I do see that HP also refers to Link aggregation as LAG.
Will they work together? Or will I have to seperate the AP manager interfaces to seperate ports?
Justin
1 ACCEPTED SOLUTION
Re: WLC LAG to HP switch
Justin,
     I have been on many cases where the WLC has been connected to an HP switch configured for LAG.  This does work, you just need to make sure the VLAN's are configured properly on the HP trunk. i.e. make sure you set the tagged/untagged/no bits properly.
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Justin,
Thanks for the quick and accurate assistance!
I am receiving my new 5508 WLC today with 4 GLC-T connectors, and have an HP ProCurve 3500yl-48G switch. What configuration on the WLC and the 3500 do I need to set up in order to use all 4 ports?
VLAN's:
Wired user VLAN 2
Server VLAN 3
Internal Wireless VLAN 4
Guest Wireless VLAN 12
WIreless Management VLAN 40
on the HP, you need to do a Trunk, then set all the VLANS that will exist on the WLC to be tagged.
On the WLC, enable LAG, and tag all interfaces.  For the AP, it's a standard access port.  So long as the VLAN the AP is on can route to the WLC, it should join.
HTH,
Steve
Does it make sense to put the WLC and AP's in VLAN 40? Or should they be in separate VLANs? From what I have read the AP's should not be in the Wired or Wireless user VLAN's.
AP's can be in the same VLAN as the WLC with no issues.  But don't put them in the same VLAN as any wireless client.
Per best practices, it's only recommmended to have 60-80 AP in a singular VLAN.
HTH,
Steve
can you show an example of your HP switch configuratoin.  It states that the Cisco 5508 does not support LACP.  Can the HP switch be configured for an ether-channel without LACP?  Also, on a Cisco switch configuration you must configure src-dst-ip for load balancing on the ether-channel.  Can you share you HP side of the configuratoin?  THanks
2354
