WLC Management Interface as VLAN 0
lcaruso
Level 6
Level 6
I understand it is a best practice to have the managment interface set to vlan 0 on the WLC. Why?
If multiple ports are trunked to the WLC and the WLC has an address in vlan 3, does that work or how do I make that work?
Right now the WLC is set to vlan 3 on the managment interface and a port channel is setup to pass vlan 3 along with the wlan vlans.
Thanks.
4 Accepted Solutions
Scott Fella
It was documented in earlier versions of the WLC code. I believe in v7.0 and later, it was suggested you tag the manager vlan due to QoS requirements. I typically will tag the manager interface in all my installs.
-Scott
Saurav Lodh
Level 7
Level 7
it is recommended to use tagged VLANs for the management interface ( non zero value )
Yeah... if you looked at older docs, it does tell you to set it to 0 and make sure you have the native vlan set on the trunk.  Newer docs have it telling you to tag the management:)
Step 3 in this v7.0 guide:
http://www.cisco.com/en/US/docs/wireless/controller/7.0MR1/configuration/guide/cg_ports_interfaces.html#wp1286790
VLAN identifier
Note Enter 0 for an untagged VLAN or a nonzero value for a tagged VLAN. We recommend using tagged VLANs for the management interface.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Following Unified Wireless QoS Technote gives clear information about the QoS in general & importance to have a tagged vlan for management. Please read it as well
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a0080c01d2c.shtml
Rasika
6 Replies 6
Scott Fella
-Scott
So that explains why someone from a certain support organization told me to use vlan 0 and then seemed to waffle on it later. Thanks Scott.
VLAN identifier
Scott
-Scott
Saurav Lodh
Level 7
Level 7
Rasika
Thanks to all that responded. All answers were marked as correct
