WLC - Running Config ?
Hello All,
I am running a WLC  ( please see the table below for the details ) with 8 AP attacted to it
Software Version5.1.151.0
Model No.AIR-WLC2112-K9
My question is :
-> I need to check (  and do a backup for ) the current configuration for each AP's What would be the simpliest and the easiest way to do that ?
Thanks in advance,
Soofi
Hall of Fame Super Gold
Re: WLC - Running Config ?
Each individual configuration of the APs????
The WLC manages the configuration of all the APs.  In a controller-based environment, the APs act like a virtual antennae.
Yes for the each indiviual AP's. How can check the configuration.
Soofi
Previous answer is correct.
5.1 just produces XML config files when you save the config via TFTP.
the closest you can get to have a list of commands is "show running-config" but those are not in the right order and so on.
And as the previous answer said, this is WLC config, not APs config
518
