Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
WLC & Swich vlan-int communication issues
I have a Cisco-Switch configured with 3-VLANs (1,3 & 6) .  im using VLAN-1 as the management vlan for communication between WLC & Switch.
I have 1-management interface and 2-dynamic interfaces created on WLC.  management-int is using untagged vlan.  and from the Cisco-Switch i can ping WLC Management-int ip.  but i can not ping other WLC Dynamic-interfaces,  while all the subnets-ips are configured properly.  also wifi clients can not connect through those dynamic-interfaces ssids
can any one help please,  here is some config outputs from my WLC >>>>>>>>>>>>>>>>>
(Cisco Controller) >show wlan summary
Number of WLANs.................................. 3
WLAN ID  WLAN Profile Name / SSID               Status    Interface Name
1        FMFB-WIFI-MGT / FMFB-WIFI-MGT          Enabled   management
2        FMFB-HO-LAN / FMFB-HO                  Enabled   vlan-3
3        FMFB HO Guest / FMFB-Guest             Enabled   vlan-6
(Cisco Controller) >show interface summary
Number of Interfaces.......................... 4
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
management                       1    untagged 192.168.2.239   Static  Yes    No
virtual                          N/A  N/A      1.1.1.1         Static  No     No
vlan-3                           1    3        192.168.100.239 Dynamic No     No
vlan-6                           1    6        192.168.110.239 Dynamic No     No
(Cisco Controller) >show interface detailed management
Interface Name................................... management
MAC Address...................................... 50:06:04:ca:97:20
IP Address....................................... 192.168.2.239
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.2.250
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. 192.168.2.250
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Disabled
--More-- or (q)uit
(Cisco Controller) >show interface detailed vlan-3
Interface Name................................... vlan-3
MAC Address...................................... 50:06:04:ca:97:24
IP Address....................................... 192.168.100.239
IP Gateway....................................... 192.168.100.1
VLAN............................................. 3
NAS-Identifier................................... HO_WLC
Primary DHCP Server.............................. Unconfigured
AP Manager....................................... No
--More-- or (q)uit
L2 Multicast..................................... Enabled
1 ACCEPTED SOLUTION
You are configuring the port as acces port:
>> switchport mode access
remove the above command and replace it with:
>> switchport mode trunk.
Amjad
Rating useful replies is more useful than saying "Thank you"
Show us the switchport config.
You must have a trunk with all VLANs on the WLC allowed.
I noticed that you are not enabling LAG. it is recommended to enable it.
Amjad
it is my switch port config,
interface FastEthernet0/23
description  connected-to-ap
switchport trunk allowed vlan 1,3,6
no ip address
interface FastEthernet0/24
description  connected-to-WLC
no ip address
I also enabled LAG, but with no result still>>>>>>>>>
Amjad
219
