Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
WLC Upgrade problems (disable unit)
Hello.
I am complete rookie in the wireless area. I have to implement a mesh wireless network and a WLC 4404 was given to me.
I started the WLC, configured a few IPs, country, etc, and then I rebooted the unit.
When rebooting I got this error, when services are starting:
- Starting LOCP: LOCP Key not found (error).    (after this the WLC stops and I can´t do anything more)
I then decided to upgrade the image via CLI, while pressing the ESC button on startup (from 5.1.151.0 to K9-6-0-182-0.aes) and getting the following menu:
    Boot Options
Please choose an option from below:
1. Run primary image (version 5.1.151.0) (active)
2. Run backup image (version 5.1.151.0)
3. Manually update images
4. Change active boot image
5. Clear Configuration
Please enter your choice:
I chose option 3, put some IPs and before upgrading it stated the following:
You have entered:
IP address     : 192.168.1.1
Netmask        : 255.255.255.0
Gateway        : 192.168.1.10
Server IP Addr : 192.168.1.10
Is this Correct (Y/n)? y
!!! WARNING updating using .aes or unapproved files will disable this unit !!!
So the WLC doens´t boot and I can not upgrade to an .aes image, but all images are .aes.
Any ideias on how to upgrade the RTOS of the WLC to 6-0-182-0.aes, or on how to boot it normally with the original image?
Thanks in advanced,
Joao Ribau
P.S. - does anyone know of a good doc on mesh networks?
1 REPLY
Hall of Fame Super Gold
Re: WLC Upgrade problems (disable unit)
I think (emphasis on the word "think") I may know where the problem lies.
You said "implement a mesh wireless network and a WLC 4404" but the firmware you are using is 5.1.151.0.  This version is for standard LWAPP/CAPWAP and not a valid Mesh firmware.
Hope this helps.
774
