03-19-2012 09:12 AM - edited 07-03-2021 09:49 PM
Can we change the internal web authentication for guest network to use http instead of https?
03-19-2012 09:15 AM
Yes u can... der s a catch..
1>> if ur running WLC code below 7.2.X then the only option is to disable HTTPS globally (Meaning HTTPS management access disabled only HTTP).
2>> If you are running 7.2.X and above, then you can use HTTP for client webauth and then HTTPS for Management access.
Please let me know if this answered your questions and dont forget to rate the usefull posts!!
Surendra
04-12-2012 08:50 PM
Surrendra,
I can't find any documentation from Cisco on how to configure to allow https for WLC management and http for client webauth. I am on 7.2.X. Can you publish the link to configure this?
JJ
04-12-2012 10:48 PM
fairly sure the syntax you are looking for is: config network web-auth secureweb disable
It will still require a reboot for the redirector to function, but that will get you HTTPS MGMT and HTTP Web Auth.
