WLC5500 and AP1250
I have some questions about WLC5500 and AP1250:
1) How many SSIDs are supported?
2) Is supported EAP-MD5 in this AP?
3) What is the Throughput of the WLC for encrypted traffic?
4) Is possible authenticat user (802.1x) in physical interfaces (RJ45)?
5) Can I specify radius server for each SSID?
6) Have this solution (WLC5500 and AP1250) support  for EAP Offload?
7) Have counters in access-lists?
Thank in advance.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: WLC5500 and AP1250
1.  You can configure up to 512 SSID but only 16 SSID will be operational at any one time.
3.  Encrypted traffic?  You mean OfficeExtend?  1250 does NOT support OfficeExtend.  11430 and 1140 do.  DO you mean full wireless traffic or LWAP only traffic?
5.  Yes.  Go through the configuration guide and it'll show you how.
7.  You can but on the switch infrastructure and no on the LWAP or the WLC.
Message was edited by: leolaohoo
Thank leolaohoo.
The Cisco Support answered questions:
1) How many SSIDs are supported? 16 SSIDs are supported.
2) Is supported EAP-MD5 in this AP? Yes
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b-chap11-authtypes.html#wpmkr1073044
Miercom report test the throughput with 4Gbps traffic load with a 92% throughput.
4) Is possible authenticat user (802.1x) in physical interfaces (RJ45)? Yes
5) Can I specify radius server for each SSID? No, you can configure a secondary server.
6) Have this solution (WLC5500 and AP1250) support for EAP Offload? EAP supported by the WLC is shown on the following link. EAP Offload is used by another brand.
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60sol.html#wpmkr1261179
64 ACLs/64 lines limitation
853
