WLC5508 problem connect AIR-CAP1602I-R-K9
Добрый день,
Точка Air-cap1602 не может подключиться к контроллеру,
В чем может быть проблема?
Спасибо.
AP885a.92bb.97ab#sh inventory
NAME: "AP1600", DESCR: "Cisco Aironet 1600 Series (IEEE 802.11n) Access Point"
PID: AIR-CAP1602I-R-K9 , VID: V01, SN: FGL1744W6WG
AP885a.92bb.97ab# sh version
Cisco IOS Software, C1600 Software (AP1G2-K9W8-M), Version 15.2(2)JB2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 29-Jul-13 12:35 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
AP885a.92bb.97ab uptime is 2 hours, 58 minutes
System image file is "flash:/ap1g2-k9w8-mx.152-2.JB2/ap1g2-k9w8-mx.152-2.JB2"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1602I-R-K9    (PowerPC) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FGL1744W6WG
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.4.110.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 88:5A:92:BB:97:AB
Part Number                          : 73-14671-04
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC17432XWL
Top Assembly Part Number             : 800-38552-01
Top Assembly Serial Number           : FGL1744W6WG
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1602I-R-K9
Configuration register is 0xF
(Cisco Controller) >show inventory
Burned-in MAC Address............................ C0:67:AF:1A:CF:A0
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 12
NAME: "Chassis"    , DESCR: "Cisco 5500 Series Wireless LAN Controller"
PID: AIR-CT5508-K9,  VID: V03,  SN: FCW1748L07P
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.110.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS + LDPE
System Name...................................... CISCO-CAPWAP-CONTROLLER
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 10.1.0.66
Last Reset....................................... Software reset
System Up Time................................... 0 days 23 hrs 37 mins 52 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
--More-- or (q)uit
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +42 C
External Temperature............................. +22 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
(Cisco Controller) >*spamApTask7: Jan 30 16:43:11.448: 64:e9:50:af:66:70 Discarding non-ClientHello Handshake OR DTLS encrypted packet from  10.103.24.11:47484)since DTLS session is not established
*spamApTask6: Jan 30 16:43:11.556: 64:e9:50:af:66:70 Discovery Request from 10.103.24.11:47483
*spamApTask6: Jan 30 16:43:11.556: 64:e9:50:af:66:70 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 12, joined Aps =0
*spamApTask6: Jan 30 16:43:11.557: 64:e9:50:af:66:70 Discovery Response sent to 10.103.24.11:47483
*spamApTask6: Jan 30 16:43:21.552: 64:e9:50:af:66:70 DTLS connection not found, creating new connection for 10:103:24:11 (47483) 10:1:0:66 (5246)
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCID: called to evaluate <cscoDefaultIdCert>
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCID: comparing to row 0, ID cert >bsnOldDefaultIdCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCID: comparing to row 1, ID cert >bsnDefaultIdCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCID: comparing to row 2, ID cert >cscoDefaultIdCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCertFromCID: called to get cert for CID 1301e815
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultIdCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultIdCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetCertFromCID: comparing to row 2, certname >cscoDefaultIdCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetSshPrivateKeyFromCID: called to get key for CID 1301e815
*spamApTask6: Jan 30 16:43:21.553: sshpmGetSshPrivateKeyFromCID: comparing to row 0, certname >bsnOldDefaultIdCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetSshPrivateKeyFromCID: comparing to row 1, certname >bsnDefaultIdCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetSshPrivateKeyFromCID: comparing to row 2, certname >cscoDefaultIdCert<
*spamApTask6: Jan 30 16:43:21.553: sshpmGetSshPrivateKeyFromCID: match in row 2
*spamApTask6: Jan 30 16:43:21.879: sshpmGetIssuerHandles: locking ca cert table
*spamApTask6: Jan 30 16:43:21.879: sshpmGetIssuerHandles: calling x509_alloc() for user cert
*spamApTask6: Jan 30 16:43:21.879: sshpmGetIssuerHandles: calling x509_decode()
*spamApTask6: Jan 30 16:43:21.883: sshpmGetIssuerHandles: <subject> C=US, ST=California, L=San Jose, O=Cisco Systems, CN=AP1G2-885a92bb97ab, MAILTO=support@cisco.com
*spamApTask6: Jan 30 16:43:21.883: sshpmGetIssuerHandles: <issuer>  O=Cisco Systems, CN=Cisco Manufacturing CA
*spamApTask6: Jan 30 16:43:21.883: sshpmGetIssuerHandles: Mac Address in subject is 88:5a:92:bb:97:ab
*spamApTask6: Jan 30 16:43:21.883: sshpmGetIssuerHandles: Cert Name in subject is AP1G2-885a92bb97ab
*spamApTask6: Jan 30 16:43:21.883: sshpmGetIssuerHandles: Cert is issued by Cisco Systems.
*spamApTask6: Jan 30 16:43:21.883: sshpmGetCID: called to evaluate <cscoDefaultMfgCaCert>
*spamApTask6: Jan 30 16:43:21.883: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*spamApTask6: Jan 30 16:43:21.883: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*spamApTask6: Jan 30 16:43:21.884: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*spamApTask6: Jan 30 16:43:21.884: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*spamApTask6: Jan 30 16:43:21.884: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*spamApTask6: Jan 30 16:43:21.884: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*spamApTask6: Jan 30 16:43:21.884: sshpmGetCertFromCID: called to get cert for CID 2b59913d
*spamApTask6: Jan 30 16:43:21.884: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*spamApTask6: Jan 30 16:43:21.884: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*spamApTask6: Jan 30 16:43:21.884: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*spamApTask6: Jan 30 16:43:21.884: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*spamApTask6: Jan 30 16:43:21.884: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*spamApTask6: Jan 30 16:43:21.884: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*spamApTask6: Jan 30 16:43:21.884: ssphmUserCertVerify: calling x509_decode()
*spamApTask6: Jan 30 16:43:21.894: ssphmUserCertVerify: user cert verfied using >cscoDefaultMfgCaCert<
*spamApTask6: Jan 30 16:43:21.894: sshpmGetIssuerHandles: ValidityString (current): 2014/01/30/16:43:21
*spamApTask6: Jan 30 16:43:21.894: sshpmGetIssuerHandles: ValidityString (NotBefore): 2013/10/29/01:36:25
*spamApTask6: Jan 30 16:43:21.894: sshpmGetIssuerHandles: ValidityString (NotAfter): 2023/10/29/01:46:25
*spamApTask6: Jan 30 16:43:21.894: sshpmGetIssuerHandles: getting cisco ID cert handle...
*spamApTask6: Jan 30 16:43:21.894: sshpmGetCID: called to evaluate <cscoDefaultIdCert>
*spamApTask6: Jan 30 16:43:21.894: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*spamApTask6: Jan 30 16:43:21.894: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*spamApTask6: Jan 30 16:43:21.894: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*spamApTask6: Jan 30 16:43:21.894: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*spamApTask6: Jan 30 16:43:21.894: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*spamApTask6: Jan 30 16:43:21.894: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*spamApTask6: Jan 30 16:43:21.894: sshpmGetCID: comparing to row 0, ID cert >bsnOldDefaultIdCert<
*spamApTask6: Jan 30 16:43:21.894: sshpmGetCID: comparing to row 1, ID cert >bsnDefaultIdCert<
*spamApTask6: Jan 30 16:43:21.894: sshpmGetCID: comparing to row 2, ID cert >cscoDefaultIdCert<
*spamApTask6: Jan 30 16:43:21.902: sshpmFreePublicKeyHandle: called with 0x2c20d0e4
*spamApTask6: Jan 30 16:43:21.902: sshpmFreePublicKeyHandle: freeing public key
*spamApTask6: Jan 30 16:43:22.089: 64:e9:50:af:66:70 Allocated index from main list, Index: 441
*spamApTask6: Jan 30 16:43:22.089: 64:e9:50:af:66:70 DTLS keys for Control Plane are plumbed successfully for AP 10.103.24.11. Index 442
*spamApTask6: Jan 30 16:43:22.089: 64:e9:50:af:66:70 DTLS Session established server (10.1.0.66:5246), client (10.103.24.11:47483)
*spamApTask6: Jan 30 16:43:22.089: 64:e9:50:af:66:70 Starting wait join timer for AP: 10.103.24.11:47483
*spamApTask6: Jan 30 16:43:22.091: 64:e9:50:af:66:70 Join Request from 10.103.24.11:47483
*spamApTask6: Jan 30 16:43:22.092: 64:e9:50:af:66:70 Deleting AP entry 10.103.24.11:47483 from temporary database.
*spamApTask6: Jan 30 16:43:22.092: 64:e9:50:af:66:70 Join Version: = 117730816
*spamApTask6: Jan 30 16:43:22.093: 64:e9:50:af:66:70 Join resp: CAPWAP Maximum Msg element len = 100
*spamApTask6: Jan 30 16:43:22.093: 64:e9:50:af:66:70 Join Response sent to 10.103.24.11:47483
*spamApTask6: Jan 30 16:43:22.093: 64:e9:50:af:66:70 CAPWAP State: Join
*spamApTask6: Jan 30 16:43:22.093: 64:e9:50:af:66:70 capwap_ac_platform.c:1225 - Operation State 0 ===> 4
*apfReceiveTask: Jan 30 16:43:22.094: 64:e9:50:af:66:70 Register LWAPP event for AP 64:e9:50:af:66:70 slot 0
*apfReceiveTask: Jan 30 16:43:22.095: 64:e9:50:af:66:70 Register LWAPP event for AP 64:e9:50:af:66:70 slot 1
*spamApTask6: Jan 30 16:43:22.226: 64:e9:50:af:66:70 Configuration Status from 10.103.24.11:47483
*spamApTask6: Jan 30 16:43:22.226: 64:e9:50:af:66:70 CAPWAP State: Configure
*spamApTask6: Jan 30 16:43:22.226: 64:e9:50:af:66:70 Updating IP info for AP 64:e9:50:af:66:70 -- static 1, 10.1.0.67/255.255.255.0, gtw 10.1.0.128
*spamApTask6: Jan 30 16:43:22.227: 64:e9:50:af:66:70 Configured Static IP Address not valid for AP 64:e9:50:af:66:70
*spamApTask6: Jan 30 16:43:22.227: 64:e9:50:af:66:70 Updated IP Domain info for AP 64:e9:50:af:66:70 -- set 0, Domain
*spamApTask6: Jan 30 16:43:22.227: 64:e9:50:af:66:70 Updating IP NamServer info for AP 64:e9:50:af:66:70 -- set 0, nameserver 0.0.0.0
*spamApTask6: Jan 30 16:43:22.227: 64:e9:50:af:66:70 AP 64:e9:50:af:66:70: Invalid country code ().
*spamApTask6: Jan 30 16:43:22.228: 64:e9:50:af:66:70 PHY_TX_POWER_PAYLOAD: Invalid Tx Power Level 0
*spamApTask6: Jan 30 16:43:22.228: 64:e9:50:af:66:70 Channel 13 is invalid in the domain
*spamApTask6: Jan 30 16:43:22.228: 64:e9:50:af:66:70 AP 64:e9:50:af:66:70: Invalid country code ().
*spamApTask6: Jan 30 16:43:22.228: 64:e9:50:af:66:70 Channel 161 is invalid in the domain
*spamApTask6: Jan 30 16:43:22.228: 64:e9:50:af:66:70 Setting MTU to 1485
*spamApTask6: Jan 30 16:43:22.228: 64:e9:50:af:66:70 Regulatory Domain Mismatch: AP 64:e9:50:af:66:70 not allowed to join. Regulatory Domain check failed.
        Allow
*spamApTask6: Jan 30 16:43:22.228: 64:e9:50:af:66:70 Finding DTLS connection to delete for AP (10:103:24:11/47483)
*spamApTask6: Jan 30 16:43:22.228: 64:e9:50:af:66:70 Disconnecting DTLS Capwap-Ctrl session 0x1702d4a0 for AP (10:103:24:11/47483)
*spamApTask6: Jan 30 16:43:22.228: 64:e9:50:af:66:70 CAPWAP State: Dtls tear down
*spamApTask6: Jan 30 16:43:22.229: 64:e9:50:af:66:70 DTLS keys for Control Plane deleted successfully for AP 10.103.24.11
*spamApTask6: Jan 30 16:43:22.236: 64:e9:50:af:66:70 Failed post decode processing of config status from 10.103.24.11:47483
*spamApTask6: Jan 30 16:43:22.236: 64:e9:50:af:66:70 State machine handler: Failed to process  msg type = 5 state = 5 from 10.103.24.11:47483
AP885a.92bb.97ab#
*Jan 30 17:00:47.163: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jan 30 17:00:53.087: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 30 17:00:53.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.0.66 peer_port: 5246
*Jan 30 17:00:53.539: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.0.66 peer_port: 5246
*Jan 30 17:00:53.539: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.0.66
*Jan 30 17:00:53.539: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Jan 30 17:00:53.539: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Jan 30 17:00:53.539: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Jan 30 17:00:53.539: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.1.0.66
., 1)30 17:01:11.671: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceeded max(UNKNOWN_MESSAGE_TYPE (5)
*Jan 30 17:01:11.671: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Jan 30 17:01:11.671: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.1.0.66:5246
*Jan 30 17:01:11.715: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Jan 30 17:01:11.735: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jan 30 17:01:11.735: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jan 30 17:01:11.747: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 30 17:01:11.779: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan 30 17:01:12.735: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jan 30 17:01:12.783: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Jan 30 17:01:12.791: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jan 30 17:01:13.775: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jan 30 17:01:13.783: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Jan 30 17:01:13.811: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan 30 17:01:13.819: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jan 30 17:01:13.827: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jan 30 17:01:14.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Jan 30 17:01:14.819: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jan 30 17:01:14.855: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 30 17:01:15.855: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
1 ACCEPTED SOLUTION
Highlighted
VIP Purple
Re: WLC5508 problem connect AIR-CAP1602I-R-K9
If you are in Russia then change the country cod eon WLC.
Here is the procedue:
Change the country code on WLC.
GUI:
Disable both Network first
Choose Wireless > 802.11a/n > Network, Unselect the 802.11a Network Status check box.,Click Apply
Choose Wireless > 802.11b/g/n > Network.,Unselect the 802.11b/g Network Status check box.,Click Apply
Then
Wireless > Country and there you can change the county to Russian.
After changing the Country you must enable both networks again.
CLI:
Change the country code of a WLC, you must disable the 802.11a and 802.11b network :
>config 802.11a disable network
>config 802.11b disable network
Now you can change the country code of the controller. For example, we change it from US to Mexico
>config country RU
After changing the country,enable the 802.11 interfaces.
>config 802.11a enable network
>config 802.11b enable network
Dont forget to rate helpful posts
VIP Purple
HI ,
you ahve a wrong regulatery domain on AP.
If you are in USA then the access point should be  AIR-CAP1602I-A-K9
Which country are you in ??
Hello, sandeepchoudhary21
My country Russia.
Highlighted
VIP Purple
GUI:
Then
CLI:
>config country RU
Thank you,
It works!
309
