WLC8500 won't boot after initial console config
I'm having an issue trying to get 2 WLC 8500 to boot which have the same issue.  After initially configuring the management ip, service port, etc. via serial console, saving and restarting - the boot up session hangs at the "Broadcom NetXtreme II Ethernet Boot Agent v5.2.7".  I've tried power cycling both units a couple times via the front panel power button, reconfiguring the BIOS to not boot to network and select the hard drive as the first boot device, but I can't seem to get past this.
Logs below
Configuration correct? If yes, system will save it and reset. [yes][NO]: yes
Configuration saved!
Resetting system with new configuration...
SoftDog: Unexpected close, not stopping watchdog!
umount: /mnt/wlc: device is busy
please save console output below and send to DE
                     USER        PID ACCESS COMMAND
/mnt/wlc:            root       3530 f.c.. licensed
INIT: Sending processes the TERM signal
Stopping portmap daemon....
Sending all processes the TERM signal... done.
Sending all processes the KILL signal... done.
Stopping hotplug subsystem:
   pci
   pci      [success]
   usb
   usb      [success]
   isapnp
   isapnp   [success]
   ide
   ide      [success]
   input
   input    [success]
   scsi
   scsi     [success]
done.
Starting reboot command: reboot
Rebooting...
Restarting system.
Platform Initalization Complete
System x3550 M3
UEFI Build Ver: 1.11    IMM Build Ver: 1.25   Diagnostics Build Ver: 9.32
2 CPU Packages Available at 5.86GT/s Link Speed
16384MB Memory Available at 1067MHz in Independent Channel Mode
Start boot option
~whitespace removed~
<F1> Setup          <F2> Diagnostics    <F12> Select Boot Device
Boot Failed. CD/DVD Rom
Boot Failed. Floppy Disk
Please wait, initializing legacy usb devices...Done        Broadcom NetXtreme II Ethernet Boot Agent v5.2.7                                Copyright (C) 2000-2009 Broadcom Corporation                                    All rights reserved.
I'm stuck at this point on both units.  Seems like an issue someone must have come accross before.
Thanks for any suggestions you may have.
Cheers,
Greg
Update:  Console is currently connected via Cyclade terminal at an off-site location.  An RMA has been ordered and both old and new units will be tested onsite with a laptop serial connection and Putty next week.
Hi, did you make it work?. I
Hi, did you make it work?. I have a recently purchased 8500 and now I am facing the same issue.
thanks
AC
As soon as I changed the USB
As soon as I changed the USB-Serial cable converter and connect a PROLIFIC instead of the TRENDNet that I had, I could access right away the WLC 8500. I have been using the TRENDNet for a long period of time with no issues connecting to Cisco Devices so I would have to take a look on this.
I reboot completely the WLC and now I can see everything on the console connection. I am attaching to this case a brief procedure with screenshots that I made just in case that somebody else face the same problem.
AC
Abraham is on the right track
Abraham is on the right track.  The serial interface on these systems seems really sensitive.  Once we removed the Cyclade serial connection, the 8500 had no issues booting up.  I had no issues with a couple different standard USB->Serial adapters on a laptop but haven't tested any other out of band console server type appliances.
230
