WMM Issue
I have deployed a couple of 1600 Series access points and a Cisco 2504 WLC. The issue I have it's that the speed on downlink (AP to STA) it's half the speed in the uplink direction (STA to AP). If I turn the WMM off (of course I lose 802.11n capability) the speed it's almost the same in both directions. I know what WMM does and how it's supposed to work, but I don't think this behaviour it's normal. The QoS profile it's set to Platinum (voice), but the results are the same no matter what profile I chose. Any thoughts on this ?
Re: WMM Issue
The speed a client connects at is based around the RSSI and SNR. So it is entirely possible that the AP and client would have different rates each direction. QoS wouldn't necessarily have an effect on the actual data transfer rates, just how the traffic gets queued. Further of the client/application isn't marking traffic with an appropriate dscp the QoS on the WLAN becomes moot.
What youngest to look at is the signal strength and quality on the client as well as the AP/WLC which will help you determine what sustainable rate they can each use to pass traffic.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Re: WMM Issue
I forgot to mention that the test was done with an Intel AGN5100 wireless card (but this issue affects all clients) and the SNR was perfect (look below for further evidence).
      Radio Signal Strength Indicator............ -48 dBm
      Signal to Noise Ratio...................... 47 dB
Also on the client side the software reported that the link speed is 300 Mbps and on the controller the coding scheme was m15.
Here is the detailed picture regarding other parameters:
AP radio slot Id................................. 1
Client State..................................... Associated
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 1
Hotspot (802.11u)................................ Not Supported
BSSID............................................ 7c:95:f3:6c:c6:3f
Connected For ................................... 371 secs
Channel.......................................... 36
Association Id................................... 1
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Client CCX version............................... 4
Client E2E version............................... 1
Re-Authentication Timeout........................ 16420
QoS Level........................................ Platinum
Avg data Rate.................................... 0
Burst data Rate.................................. 0
Avg Real time data Rate.......................... 0
Burst Real Time data Rate........................ 0
802.1P Priority Tag.............................. disabled
CTS Security Group Tag........................... Not Applicable
KTS CAC Capability............................... No
WMM Support...................................... Enabled
  APSD ACs.......................................  BK  BE  VI  VO
Power Save....................................... OFF
Current Rate..................................... m15
Supported Rates.................................. 6.0,9.0,12.0,18.0,24.0,36.0,
    ............................................. 48.0,54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Policy Manager Rule Created...................... Yes
Audit Session ID................................. 0aac1f0400001c855267f15a
AAA Role Type.................................... none
Local Policy Applied............................. none
IPv4 ACL Name.................................... none
IPv4 ACL Applied Status.......................... Unavailable
IPv6 ACL Name.................................... none
IPv6 ACL Applied Status.......................... Unavailable
Layer2 ACL Name.................................. none
Layer2 ACL Applied Status........................ Unavailable
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
No. of mDNS Services Advertised.................. 0
Policy Type...................................... WPA2
Authentication Key Management.................... 802.1x
Encryption Cipher................................ CCMP (AES)
Protected Management Frame ...................... No
Management Frame Protection...................... No
EAP Type......................................... 0
Client Capabilities:
      CF Pollable................................ Not implemented
      CF Poll Request............................ Not implemented
      Short Preamble............................. Not implemented
      PBCC....................................... Not implemented
      Channel Agility............................ Not implemented
      Listen Interval............................ 60
      Fast BSS Transition........................ Not implemented
Client Wifi Direct Capabilities:
      WFD capable................................ No
      Manged WFD capable......................... No
      Cross Connection Capable................... No
      Support Concurrent Operation............... No
Fast BSS Transition Details:
Client Statistics:
      Number of Bytes Received................... 308560537
      Number of Bytes Sent....................... 163416022
      Number of Packets Received................. 273317
      Number of Packets Sent..................... 217337
      Number of Interim-Update Sent.............. 0
      Number of EAP Id Request Msg Timeouts...... 0
      Number of EAP Id Request Msg Failures...... 0
      Number of EAP Request Msg Timeouts......... 0
      Number of EAP Request Msg Failures......... 0
      Number of EAP Key Msg Timeouts............. 0
      Number of EAP Key Msg Failures............. 0
      Number of Data Retries..................... 14412
      Number of RTS Retries...................... 0
      Number of Duplicate Received Packets....... 0
      Number of Decrypt Failed Packets........... 0
      Number of Mic Failured Packets............. 0
      Number of Mic Missing Packets.............. 0
      Number of RA Packets Dropped............... 0
      Number of Policy Errors.................... 0
Client Rate Limiting Statistics:
      Number of Data Packets Recieved............ 0
      Number of Data Rx Packets Dropped.......... 0
      Number of Data Bytes Recieved.............. 0
      Number of Data Rx Bytes Dropped............ 0
      Number of Realtime Packets Recieved........ 0
      Number of Realtime Rx Packets Dropped...... 0
      Number of Realtime Bytes Recieved.......... 0
      Number of Realtime Rx Bytes Dropped........ 0
      Number of Data Packets Sent................ 0
      Number of Data Tx Packets Dropped.......... 0
      Number of Data Bytes Sent.................. 0
      Number of Data Tx Bytes Dropped............ 0
      Number of Realtime Packets Sent............ 0
      Number of Realtime Tx Packets Dropped...... 0
      Number of Realtime Bytes Sent.............. 0
      Number of Realtime Tx Bytes Dropped........ 0
PS: The speed using the above configuration is 32 Mbps on downlink and 80 Mbps on uplink (more than double). Another important thing that worth mentioning it's that without the controller (an AP in standalone mode) I don't have this problem.
Re: WMM Issue
what driver are you running?  i have seen issue with driver in CUWN vs aIOS deployments
HTH,
Steve
WMM Issue
As I told you this issue affects all clients (no matter what wireless card or OS). This problem is present only on clients that connects via 802.11n, on a/g everything it's normal. The driver version it's 14.3.2.1 but I have another laptop with Intel Centrino Advanced N 6235 (driver 15.10.3.2) with exactly the same problem.
Hall of Fame Super Silver
Re: WMM Issue
How are you testing? I would also use jperf to test and not use any online speed test. Jperf is free and is what I use to test throughput. There is a known issue with the 5ghz and the v14 of the driver but is fixed in v15.
-Scott
Re: WMM Issue
Post your
show WLAN
show interface summary
-Scott
Re: WMM Issue
show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... Test
Network Name (SSID).............................. Test
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Enabled
Network Admission Control
Client Profiling Status
    Radius Profiling ............................ Disabled
     DHCP ....................................... Disabled
     HTTP ....................................... Disabled
    Local Profiling ............................. Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 10
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 28800 seconds
User Idle Timeout................................ 60 seconds
Sleep Client..................................... disable
Sleep Client Timeout............................. 12 hours
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... WLC_Int
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Platinum
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 3
DTIM period for 802.11b radio.................... 3
Radius Servers
   Authentication................................ x.x.x.x 1812
   Accounting.................................... Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
      WPA2 (RSN IE).............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   flexconnect PPPoE pass-through................ Disabled
   flexconnect local-switching IP-source-guar.... Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Disabled
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Split Tunnel (Printers).......................... Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Enabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority  Policy Name
Number of Interfaces.......................... 5
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
management                       1    200      10.1.31.4         Static       Yes    No
vlan_1                                 1    150      10.1.14.4      Dynamic      No     No
vlan_2                                 1    151      10.1.8.4        Dynamic      No     No
vlan_3                                 1    152      10.1.29.4      Dynamic      No     No
virtual                                N/A  N/A      10.0.0.1          Static        No     No
Re: WMM Issue
What I would do is delete that WLAN and create it again leaving the defaults settings except for the broadcast enabled or disabled, the interface and use WPA2/AES only. Don't use WPA/TKIP with WPA or don't mix and match.
-Scott
WMM Issue
I created another SSID with no authentication and no encryption. It seems that the speed has increase by 10-15 Mbps on downlink, so now I get 50 Mbps/70 Mbps downlink/uplink speed.
Re: WMM Issue
I know you mentioned, you know what WMM is and since you do are you marking your packets at the application layer ? Cuase if you aren't what are you gaining from WMM ?
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Re: WMM Issue
Packets are not marked, so the DSCP marking is 0x00. Anyway I dont't see the problem because WMM should work in both direction, so I should also get low throughput in uplink direction. Standalone APs are also using WMM and with them I don't have any problems.
Later Edit: I looked at traffic and I noticed that everything that it's comming from the controller it's marked DSCP 0x18 (CS3) and I presume that the marking it's done by the controller, probably because of the QoS Profile set (Platinium).
Re: WMM Issue
The main thing is to get the WLAN configuration correct. You had many non default settings that I wouldn't of used and the biggest thing was that you had both WPA and WPA2 enabled, which causes issue with Apple devices.
QoS markings depends on what you have set for that WLAN and what you have set for your QoS policies. That really isn't going to slow down or increase your uploads or downloads unless your over utilizing the network and QoS needs to happen.
-Scott
Re: WMM Issue
I reset everything to default and I created another SSID on which I configured only the authentication + encryption (WPA2 + AES) and everything it's exactly the same (30-35 Mbps on downlink and 75-80 Mbps on uplink).
@Abhishek Could you be more explicit ?; what QOS class map ?. The current Qos profile on controller is Silver (best effort).
Re: WMM Issue
There may be an issue of the traffic being matched bu the QOS class map
Re: WMM Issue
A related problem might be that I also have packet loss (at random times) and high latency for no obvious reason. For instance now no client (except for me it's associated to the wi-fi network) and no other acces point it's in the same channel as this one, but as you can see one packet was lost.
Reply from 10.1.31.1: bytes=32 time=3ms TTL=255
Request timed out.
Reply from 10.1.31.1: bytes=32 time=6ms TTL=255
Reply from 10.1.31.1: bytes=32 time=8ms TTL=255
Reply from 10.1.31.1: bytes=32 time=72ms TTL=255
Reply from 10.1.31.1: bytes=32 time=5ms TTL=255
Reply from 10.1.31.1: bytes=32 time=7ms TTL=255
Reply from 10.1.31.1: bytes=32 time=2ms TTL=255
Reply from 10.1.31.1: bytes=32 time=136ms TTL=255
PS: The problem can't be on the wire side, where the link latency (from WLC to AP) reported by the controller it's < 1ms.
WMM Issue
Anyone ? I'm absolutely clueless about what's happening. With WMM disable the downlink/uplink speed it's spot on (as it should be): 22 Mbps on downlink and 22 on uplink. Enable WMM and it's chaos, 30 Mbps on downlink and 80-85 Mbps on uplink.
WMM Issue
Isolate the issue... force the client on the 2.4ghz and test, then force the client on the 5ghz using only 20mhz channel width and test, then force the client on the 5ghz with 40mhz and test.  See which one works and which one give you issues.  I ran into this with Intel cards which doesn't like 40mhz, so I disable 40mhz.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
WMM Issue
The problem is the same no matter what band I chose, on 2.4 Ghz I get 20 Mbps/40 Mbps and on 5 Ghz with 20 Mhz channel I get 26 Mbps/42 Mbps, which it's rather fascinating because it's exactly half.
WMM Issue
What you need to also test is a continuos ping.  I have seen clients devices loose ping's due to 40mhz channel width.  Don't just test throughput, because if the client isn't stable using 5ghz or 40mhz channel width, your issue is with the client.  Are you using jperf?
Scott
-Scott
Re: WMM Issue
I told you earlier that for no reason and at random times my latency increases so I've capture some traffic right at the radio interface level and I disovered a rather worrying problem. Right at the point where latency increases from 3 to 150 ms one beacon frame it's missing. It is possilbe that the beacon collided with a frame sent by the STA? Or is this a bug ?
WMM Issue
What are you using to test throughput?
Scott
-Scott
Re: WMM Issue
I download/upload a file from/to a FTP server connected in the same switch as the controller. Using the copper cable instead of wireless the speed goes close to 100/100 Mbps so I don't see any problem in the way I measure the speed.
Re: WMM Issue
Well I tested with iperf and I get around 25-35 up and down. I'm using a 3602 and 802.1x. AP is also connected at 1000 Full Duplex.
-Scott
Re: WMM Issue
If you ask me that's not much if you are connected on 5 GHz (40 Mhz channel).
Re: WMM Issue
I was testing between wireless clients an iphone and iPad and iPhone to a wired PC running iperf. I really don't expect to have great throughput when transferring large files and many of my customers who do these or require large file transfers will use the wired side. In a greenfield test environment you can achieve negotiation that states 300mbps that means max with one client you might see 150mbps. Now how many clients on that channel, you would divide 150mbps and that will get you what you should theoretically see, in actuality I have never tested throughput that high. Wired is full duplex and wireless is half duplex so it's like a hub.... Everything is shared amount all devices on that channel.
-Scott
Re: WMM Issue
I must say that I'm a bit dissapointed by the performance of the Cisco WLC. I tested other vendor equipments (not so expensive) and I managed to get 170 Mbps of throughput using UDP in a normal environment (not ideal). Even with Cisco Autonomous APs I get 100+ Mbps of throughput with TCP. Yeah the centralized management it's beautiful, but the performance numbers in terms of speed just don't impress me. I hope that there is a way to fix my imbalanced throughput and I will look forward to find the issue ...
LE: And I forgot to mention the power problem which affects the 1600 series APs in the 2.4 Ghz, which instead of transmitting with 22 dbm, transmits with 12-13 dbm, which messed up all my WI-FI provisioning that I did before.
Hall of Fame Super Gold
WMM Issue
Console into the AP and post the output to the command "sh interface G0".  On your switch, post the "sh interface " on the port that connnects to the AP and the WLC.
Re: WMM Issue
Switch to WLC:
      switchport mode trunk
      load-interval 30
      mls qos trust dscp
Switch to AP:
     switchport access vlan 200
     switchport mode access
     load-interval 30
     mls qos trust dscp
WMM Issue
Switch to WLC:
load-interval 30
mls qos trust dscp
Switch to AP:
load-interval 30
mls qos trust dscp
Adrian,
These are NOT the output I am requesting.
2001
