work group bridge with cisco 3500
suthomas1
Level 6
Level 6
We have few cisco 3500 ap's which is to be used as work group bridge. I am not very sure but i think we need the ap to be in autonomous mode to make it a work group bridge. Currently it is running lwapp/capwap image.
Is this correct, please help with suggestions.
2 Accepted Solutions
Yes, your AP should have autonomos image to configure it as a WGB. WGB act as a client & connect via wirelessly to a network to either another autonomous AP or Lightweigth AP. Main use case is connecting  wired devices to a wireless network.
Below may help you to understand how to configure it in each scenario.
1. WGB connection to CAPWAP
http://mrncciew.com/2013/04/30/wgb-with-capwap/
2. WGB connection to Autonmous AP
http://mrncciew.com/2013/01/18/workgroup-bridge-wgb-configurations/
Rasika
*** Pls rate all useful responses ***
This was the summary of the issue you had
- AP was having mesh image & keep resetting. Assigning IP to Gig0 or BVI did not work to communicate with directly connected PC
- Since you did not have a WLC we could not get it convert to local mode AP & then try TFTP upload method.
- Left us only option of loading the autonomous image using MODE button & TFTP server.
Here is the summary of what we have done.
1. Download the IOS image you want to upload (ap3g1-k9w7-tar.124-25d.JA2.tar) to AP
2. Rename it as "ap3g1-k9w7-tar.default"
3. Assigned your TFTP server IP (PC directly connected to AP Gig 0) from the range of 10.0.0.2 - 10.0.0.30/8 & gateway 10.0.0.1
4. Disconnect the power to AP & Reconnect Power while holding the MODE button.
5. Release the mode button after 20-30s,(after LED status turn RED)
6. After this point, AP has downloaded the given image from TFTP server & deleted the previous images from flash.
7. AP reboots with the Autonomous image.
Here is the reference doc we were used.
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
Try to follow the same procedure for any other 3502s you have (if it has mesh image & you do not have WLC to convert it to local mode AP)
Hope that was useful to you.
Rasika
**** Pls rate all useful responses ****
25 Replies 25
Rasika
Does that mean the ap's need to be running on an autonomous image for it to act as workgroup bridge?
Yes... WGB is a feature in autonoous image and not a feature in a lightweight image.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
A very simple question here, when i try to convert the ap to autonomous image, which interface on the AP shoud i assign an ip address so that my workstation can access ap & load the new image.
shoudl work on the G0 interface
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
You can assign it to Gig 0 interface after issueing " debug capwap console cli" command. Refer below link for full conversion detail
http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
Rasika
**** Pls rate all useful responses****
Thanks all. our AP 3500 is having a BVI interface along with normal radio & gig0 interfaces.
We tried using an IP address in same subnet on gig0 interface which is connected to our workstation( in same subnet ).
But, neither of them can ping each other, the firewall on workstation is turned off.
Please suggest on this. Thank You
Try setting default gateway address of your ap as laptop IP address and see. "Capwap ap ip default-gateway x.x.x.x"
Thanks we tried that.
AP gig0 was set with ip 192.168.1.2 and the workstation was set to 192.168.1.55. Both were connected using a direct ethernet cable.
either of them couldn't ping the other.
kindly advise.
Ok, let's put AP to its default config & try this again. Follow the below & see if that helps
LAP#delete flash:private-multiple-fs
LAP#reload
This will default your AP config & username/password would be cisco/Cisco afterwords.
LAP#debug capwap console cli
LAP#conf t
LAP(config)#int g0
LAP(config-if)#ip address 192.168.1.2 255.255.255.0
LAP(config-if)#no shut
LAP(config) ip default-gateway 192.168.1.55
Configure your Laptop with 192.168.1.55/24 & gateway address 192.168.1.2 & see whether it can ping each other.
Rasika
Thanks.
We tried this also, but it doesn't work.
AP - 192.168.1.2
PC - 192.168.1.55
They still can't ping each other. We see an ip address on the BVI1 interface of AP. is this the problem?
Appreciate your advise on this.
Post show version of your AP
sh ip int brie
Interface                  IP-Address      OK? Method Status                Prot
ocol
BVI1                       10.82.6.247     YES DHCP   up                    up
Dot11Radio0                unassigned      NO  unset  up                    up
Dot11Radio1                unassigned      NO  unset  up                    up
GigabitEthernet0           192.168.1.2     YES manual up                    up
AP-OF#sh ver
Cisco IOS Software, C3500 Software (AP3G1-K9W8-M), Version 12.4(23c)JA7, RELEASE
SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 29-Jan-13 05:19 by prod_rel_team
ROM: Bootstrap program is C3500 boot loader
BOOTLDR: C3500 Boot Loader (AP3G1-BOOT-M), Version 12.4 [mpleso-ap_jmr3_esc_0514
116]
AP_OF uptime is 3 minutes
System image file is "flash:/ap3g1-k9w8-mx.124-23c.JA7/ap3g1-k9w8-xx.124-23c.JA7
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3502E-S-K9    (PowerPC460exr) processor (revision B0) with 81910K/4
9152K bytes of memory.
Processor board ID FGL1721S5G0
PowerPC460exr CPU at 666Mhz, revision number 0x18A8
Last reset from power-on
LWAPP image version 7.0.240.0
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: BC:16:65:77:D9:93
Part Number                          : 73-12175-06
PCA Assembly Number                  : 800-32268-06
PCA Revision Number                  : B0
PCB Serial Number                    : FOC171622Y6
Top Assembly Part Number             : 800-32904-02
Top Assembly Serial Number           : FGL1721S5G0
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP3502E-S-K9
Configuration register is 0xF
sh run | i def
aaa authentication login default local
That looks odd, from where this DHCP IP come to BVI interface. I am assuming you powering this AP from power adapter & AP Gig0 is directly connecting to PC
anyway try to remove this IP from the BVI
int bvi1
no ip add dhcp
See wether it helps to ping your PC from AP
If no luck, try to assign 192.168.1.2 IP to BVI interfae instead of Gig0 & see if that helps
Rasika
