zma
WPA-PSK not supported for ISE guest CWA?
I have a config with ISE hosting guest CWA for an open SSID with MAC filtering.
Everything worked fine until i was told to config a PSK before the guests were allowed to hit the CWA portal.
I tried to enable a Layer 2 security WAP-PSK but got an error
" WAP-PSK can be enabled only with Web-Auth when Radius NAC is enabled"
Has anyone done a MAC-filtering based ISE CWA with WPA-PSK? Is it not a supported configuration?
I am running ISE 1.2 and WLC5508 7.4.121.0
Thanks a lot.
  • Getting Started with Wireless
Everyone's tags (4)
1 ACCEPTED SOLUTION
VIP Purple
Hi,Please chekc the Wireless
Please chekc the Wireless LAN Controller Layer 2 – Layer 3 Security Compatibility Matrix
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/106082-wlc-compatibility-matrix.html
you shouldn't be able to enable RADIUS NAC if you're configured for a PSK.If you want to do the CWA, you will use the mac-filtering option for L2 security and set security type to None.  This will allow you to specify the RADIUS NAC option correctly.
So as per my knowledge: you can not enable wpa-pask, mac filter with CWA. you should use mac filter+NAC.
Dont forget to rate helpful posts
VIP Purple
zma
Thank you Sandeep.
Thank you Sandeep.
Hall of Fame Super Silver
For anybody researching this
For anybody researching this feature - note that in 2016 WLC software 8.3 added the ability to use both PSK and RADIUS NAC.
Reference:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn83.html#31794
Yes, that's true we can not
Yes, that's true we can not enable wpa-psk, mac filter with CWA. It can be done through the use of mac filter+NAC.
751
