WPA2 on AIR-AP1231G-A-K9
I am trying to setup WPA2 on some 1231 access points which are running IOS version Version 12.3(8)JED
The configuration is something like this:
dot11 ssid WLAN999
   vlan 999
   authentication open
   authentication key-management wpa
   wpa-psk ascii password
Int Dot11Radio0
encryption vlan 999 mode ciphers aes-ccm
ssid WLAN999
This was setup using this example:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml
Now on my newer APs (1242s, 1252s, 1141s) the WPA2 configuration looks like this:
dot11 ssid WLAN999
   vlan 999
   authentication open
   authentication key-management wpa version 2
Int Dot11Radio0
ssid WLAN999
The 1231s will not support the version 2 option at the end of the authentication key-managment command.  Is the 1231 doing WPA2 by virtue of the fact that the ciphers are set to aes-ccm?
Mike
Re: WPA2 on AIR-AP1231G-A-K9
in older code... the WPA 2 option is not der.. but when we configure AES it will act as WPA 2... in latest IOS and all we have the option to select WPA 2
I've got 12.3(8)JED on them.  There is only one later release available 12.3(8)JED1
MK
2971
