02-19-2014 11:50 AM - edited 07-05-2021 12:13 AM
Which security method is better, wpa2 aes psk or webAuth with a key/passphrase?
Sent from Cisco Technical Support Android App
02-19-2014 11:55 AM
WPA2/AES is better than WebAuth, but WebAuth is better for guest users.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
02-19-2014 12:09 PM
This is two types of autehntication:
WPA2/AES is more secure.
wpa2/aes is layer 2 and webauth is layer 3 security mechanism.
As scott mentioned, webauth is used for guest access.Keep in mind that web authentication does not provide data encryption. Web authentication is typically used as simple guest access for either a "hot spot" or campus atmosphere where the only concern is the connectivity.
Dont forget to rate helpful posts
