Wpa2-psk vs. WebAuth w/ key
Which security method is better, wpa2 aes psk or webAuth with a key/passphrase?
Sent from Cisco Technical Support Android App
  • Getting Started with Wireless
Hall of Fame Super Silver
WPA2/AES is better than WebAuth, but WebAuth is better for guest users.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
VIP Purple
This is two types of autehntication:
WPA2/AES is more secure.
wpa2/aes is layer 2 and webauth is layer 3 security mechanism.
As scott mentioned, webauth is used for guest access.Keep in mind that web authentication does not provide data encryption. Web authentication is typically used as simple guest access for either a "hot spot" or campus atmosphere where the only concern is the connectivity.
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/106082-wlc-compatibility-matrix.html
Dont forget to rate helpful posts
116
