WR and Reload Problem with AP
Hi All,
I am having more than 5000 Autonomus  AP's in my network and for taking backup config from this AP's we are using some Unix server.
Many of the Ap's work fine when taking backup. but few AP's show some logs, which causes UNIX box to keep the session for more time.
ap04#sh users
    Line       User       Host(s)              Idle       Location
*  1 vty 0     vooot001    idle                 00:00:00
                                                      ap02.u009x4.xx.com
   2 vty 1                idle                07:33:12
                                                       isp.u009x4.xx.com
so we cant save the config even manually.
ap04#wr
Unable to read configuration. Try again later.
But when we cleat the line vty, every thing work fine.
AP version:
ap04#sh ver
Cisco IOS Software, C1250 Software (C1250-K9W7-M), Version 12.4(10b)JDA3, RELEASE SOFTWARE (fc1)
ROM: Bootstrap program is C1250 boot loader
BOOTLDR: C1250 Boot Loader (C1250-BOOT-M) Version 12.4(18a)JA1, RELEASE SOFTWARE (fc1)
ap04 uptime is 1 day, 13 hours, 42 minutes
System returned to ROM by watchdog timer expired
System image file is "flash:/c1250-k9w7-mx.124-10b.JDA3/c1250-k9w7-mx.124-10b.JDA3"
Sh Flash:
ap04#sh flash:
Directory of flash:/
    2  -rwx        1945  May 20 2002 10:16:42 -06:00  private-config
    3  -rwx        2072  May 20 2002 10:16:42 -06:00  private-multiple-fs
   16  drwx         512   Jul 7 2011 13:08:06 -06:00  c1250-k9w7-mx.124-10b.JDA3
    5  drwx         128  Feb 28 2002 17:01:51 -07:00  c1250-rcvk9w8-mx
    4  -rwx       25328  May 20 2002 10:16:42 -06:00  config.txt
    8  -rwx        2817   Jul 7 2011 13:08:09 -06:00  event.log
    9  -rwx         168  May 19 2002 01:34:53 -06:00  r0.rcore
   11  -rwx         333  May 19 2002 21:43:34 -06:00  env_vars
31868928 bytes total (23104512 bytes free)
ap04#
But other AP's with similar IOS work fine. Not able to find where the problem is.
Hall of Fame Super Silver
Re: WR and Reload Problem with AP
Maybe see if you can set a timeout for the line. The issue your having is that the line sill shows in use correct?
-Scott
Thanks for reply.
Thats a good idea, but why it's not happaning with other AP's which has similar IOS etc.
Is this you are ref:
ap04(config-line)#timeout login response 200
VIP Purple
Hi Satya,
Can be due to many things:
1. The issuecomes when you have a large configuration file and immediately after exiting the configuration mode you attempt to save the configuration in NVRAM.  The issue is related to an internal timer event whose behavior cannot be modified. If you give a sufficient time between an exit from configuration mode before saving the configuration the problem will not resurface.
2. This can caused by high activity on CLI. Probably, a sh run is taking place or any other action that locks the executation of the CLI cmd.
Inshort:
1.) Memory Allocation - Reboot resolved the issue ?, I can't remember if we waiting long enough if the problem subsided on its own.
2.) Someone else was looking at the config at the same time.
Check these, It may helps.
Dont forget to rate helpful posts
Hi Sandeep,
As said before, if we clear the line vty user, am able to save config/reload/sh run....the external UNIX box use to save the config everyday, this user( isp.u009x4.xx.com) is not able to save the config, so its keepon trying. After i clear this user, every thing work fine.
VIP Purple
Hi Satya,
I think Scott suggested session time out under VTY lines. In this way any session would not last more than 5 min if you are inactive on that VTY.
AAP2(config)#line vty 0 5
AAP2(config-line)#session-timeout ?
  <0-35791>  Session timeout interval in minutes
AAP2(config-line)#session-timeout 5
Just for curiosity,What's the reason for having such a large autonomous environment ? Would controller based solution not fulfil your requirements ?
Rasika
***** Pls rate all useful responses ****
Hi Rasika,
I have tried that...its not working.Still i can see the session.
if i clear the user manually its get disconnected.
ap04#sh users all
   0 con 0                                     00:00:00
*  1 vty 0     vhn001    idle                 00:00:00 hp564.aghas.com
   2 vty 1                idle                 05:07:24
                                                       iup.u009754.hag.com
   3 vty 2                                     00:00:00
   4 vty 3                                     00:00:00
   5 vty 4                                     00:00:00
   6 vty 5                                     00:00:00
   7 vty 6                                     00:00:00
   8 vty 7                                     00:00:00
   9 vty 8                                     00:00:00
  10 vty 9                                     00:00:00
  11 vty 10                                    00:00:00
  12 vty 11                                    00:00:00
  13 vty 12                                    00:00:00
  14 vty 13                                    00:00:00
  15 vty 14                                    00:00:00
  16 vty 15                                    00:00:00
i have more than 10K LWAP's as'll...
Satya.M
Hall of Fame Super Gold
This means your IOS is buggy.
I dont think its bug,becz other AP's are working with same IOS and if i clear the users am able to giev show run and wr.
Satya
No it's a bug.
Just because you have other appliances running the same IOS and do not show the same result does not mean it's not a bug.  I've seen this several times.  I've learnt to treat this as a bug and upgrade/downgrade the IOS.
I've created a TAC Case and it is confirmed as a bug.
So if the fix is to clear the line, can't you just script that, clear the line before running the commands to get the config? Maybe your peers are not disconnecting properly. Tell your peers to log off properly if they telnet/ssh. Nothing else you can do about it.
-Scott
327
