Community Member
wrt54gh issue
can any body give me the
basic setup configuration of wrt54gh linksys wireless . i am facing problem that laptop is not detecting signal when i do basic setting kindly send ASAP
rajat
Re: wrt54gh issue
Hi Rajat,
Thanks & Regards
Re: wrt54gh issue
Rajat,
you can try few basic test. Disable the security and make it as open and unsecured connection and then search for SSID.
Make sure the ssid is set to broadcast mode.
if you are not using wireless zero configuration client (windows wireless client), try to disable third party client and refer the network.
if nothing works and this is the first time you are trying to configure the router, you can also try to reset the router (small hole in the back of the router, use the pin) and try to configure as mentioned in the config guide.
thanks,
Vinay
Thanks & Regards
Community Member
Re: wrt54gh issue
can you send any link
Re: wrt54gh issue
check this:-
http://www.home-network-help.com/wireless-router.html
thanks,
Vinay
Thanks & Regards
511
