2007 Deployer- migrating an auto-cose agent
Is anyone else having an issue using Catalog Deployer to migrate an auto-clsoe agent (the workflow type of a service in the Plan tab)? We having troubles migrating that from teh Dev environemtn to Test.
  • Intelligent Automation
Everyone's tags (1)
CatalogDeployer doesn't migrate agents. It's a known omission. You need to manually create the agent in the target site. Please enter an enhancement request to get this capability.
Does CatalogDeployer migrate adapters?
No. If it's a standard adapter and you made some changes to its properties (possible but not usually recommended), you would need to re-enter the properties in the target environment.  If it's a custom adapter, use the same procedure you used to install the adapter in the initial environment in the target environment.
346
