Add review enabled and enforce single service requisitions
Is there a way/option to make "Add review enabled" for the service, but not allow adding additional services to the requisition once Add & Review Order is clicked?
Reason being there may be services that should not be ordered together with other services (i.e. we want to make sure single requisition entry for a requisition always for a particular service), but having Add review enabled will still have benefits for these services from user experience perspective. For example, users would be able to still add the service to "cart" or Add & Review Order, hold it, review it, come back later after confirming some information, etc. before actually submitting the order. While they can edit the requisition entry/service, they should not be able to add additional services to this requisition, since this service is marked "single entry order" only of some sort.
By simply setting the service as Add review disabled, you lose this functionality and users must either submit the order on single sitting/session, or have to just start over if they need to confirm something or come back later.
Thanks.
254
