Auto-close a task
Jim Tabasz
Auto-close a task
How can I set up a task so I can just use it to attach an email notice, then automatically close the task, so the next task in the delivery plan will become active?
Use the ServiceLink Dummy Adapter to create an auto-close Agent that will automatically close any task delegated to that Agent.
Then create your 2 tasks with their respective conditions and corresponding email templates, and associate them each with this Agent (in the Workflow Type dropdown list on the General sub-tab for the task).
Only one of the tasks will fire (based on the condition), and that task will be automatically closed by the Agent.
CREATING AN AUTO-CLOSE AGENT
(1) In ServiceLink, click Agents.
(2) On the Agents page, click Create Agent.
(3) Enter a Name and Action for the agent, such as "Auto-Close".
(4) For the Outbound Adapter, select Dummy Adapter.
(5) For the Inbound Adapter, select None (auto complete).
(6) Click Submit to create the Agent.
(7) Click Start Agent to start the Agent.
(8) The Agent will now be available in the Workflow Type dropdown list on the General sub-tab for all tasks.
9 Replies 9
James Fuller
Is there a way to do this in an earlier version of RC?  Say, v2004?
Lois Donnelly
Alternative to a dummy agent would be to create the two tasks with a single child.  Each child should then be setup with a conditional expression which always evaluates to false. e.g. 0>1.  In doing so this enables the parent task to automatically close since all it's childs are completed.
I don't believe so. This is a capability of ServiceLink 2, which was introduced in RequestCenter2005.
James Fuller
Brilliant, Lois.
I'll give that a try.  Thank you.
James Fuller
Hi Lois,
In our version of RequestCenter, when the child task skips, the parent task skips.  Therefore, there isn't a way for us to do send emails from the skipped tasks.
Any other thoughts on this?
Lois Donnelly
Sorry the delay in getting back to you.  Hm, so do you have the parent task and child task evaluated?  I am guessing your version should have the ability to select when the conditional expression is evaluated (when delivery phase starts or acitivity become active) The child task that has the always false expression should be configured to evaluate when the activity becomes active.  Also if you would like please attach a screen capture of the workflow you created?
Aler
James Fuller
Lois,
The child task needed to be evaluated when the activity becomes active.  Once I set it to that, it works like a champ.
Thank you very much!
RQC
Is there a specific version of RQC2005 that you need to be on to take advantage of the auto close functionality via the ServiceLink Dummy Adapter?
Emir E
You can send 2 emails per task .. once when it becomes active and once it finishes, have you considered that?
