How can i telnet to a server using a port number from Process Orchestrator?
Hi All,
I am using Execute Windows Commands' in a process to telnet a server but process is failing with an error (return code -1).
Could anyone guide me, is it possible to  -
"telnet hostname port"
Prashant
1 REPLY
Are you trying to telnet to a
Are you trying to telnet to a host to just test the connection or are you going to telnet and execute commands?
If you are going to telnet and do commands, use the terminal target connection.
Can you expand on your use case more and tell us what you are trying to fully do?
--shaun
--Shaun Roberts shaurobe@cisco.com CIAC Adoption Pilot Engineering Lead
82
