11-17-2011 05:48 PM
how do I find Site Administrator - post upgrade
2008.3 - SANDBOX
Oracle 10g
Websphere 6.1
I just sucessfully converted a backup copy of DEV to 2008.3
I can not seem to search for the OU "Site Administration"
the only place that I can find it is on the main page > Search > Organizational Units > ALL
If I try searching Site* or Site% or just plain site nothing is returned.
Is this user error on my part?
Thank you
Daniel
Safeway
11-17-2011 05:48 PM
I just tried this in my environment and had similar results. However, if you search for "administration" or "admin" it shows up in the results. Go figure.
11-17-2011 05:48 PM
same here, however u should start using the Site Admin Role, not the OU
11-17-2011 05:48 PM
Try searching for<( a single left angle bracket) and see if the org shows up. If so, you've got a known upgrade bug, for which a fix is pending. Wouldn't hurt to report this as a defect to NCC, though.
