How to access categories in ISF
Is it possible to access categories used by a service in ISF. Is there a global variable for category. Thanks
Everyone's tags (1)
1 REPLY
What is your goal?
I don't believe this is an exposed variable available to ISF.  I believe ISF is compartmentalized to the service itself, not to the overall catalog.  While there are global ISF functions, they will only be available at the service level, not the catalog level.
I hope I understood your question.  If you could expound upon your request, that would be great.
Cheers!
155
