11-12-2013 10:47 PM
I was trying to access a web service via the “Service Link” module. I have designed the service in such a way that a task will call the agent in the Service Link module and complete it automatically when the response is stored in a field. I have tried with different adapters (HTTP/WS or Web Service Listener) and also with & without inbound adapters. In all cases, I have received an error message for the response. It seems that my request was processed and the output also sent from the webservice as a response. I believe that I am missing something which needs to be setup – to have the result stored in my dictionary field and then the task will be completed automatically.
Now the task is still available as ‘On going’ because of the error message. The error is available when I click the ‘Message Routing Exception’ link at ‘Messages’ tab under ‘View Transactions’.
The webservice is to convert Fahrenheit to Celsius and the input I have given is 105.
I tried to access the WebService available in the URL: http://www.w3schools.com/webservices/tempconvert.asmx?WSDL
The Outbound adapter I used is : HTTP/WS Adapter
The Inbound adapter I used is : HTTP/WS Adapter (or) Web Service Listener Adapter
The WSDL operation I have called : TempConvertSoap.FahrenheitToCelsius
ProcessResponse, SaveRefField properties were set as True
Outbound Request Parameter Mappings: With the “RQ_Fahrenheit” Parameter, I have mapped a text field in my dictionary for input
Outbound Response Parameter Mappings: With the “RS_FahrenheitToCelsiusResult” parameter, I have mapped a text field in my dictionary for output along with the prebuilt function “trim” in the mapping
Inbound Properties: The webservice listener adapter wsdl and routing URL was automatically available in the inbound properties
Inbound Parameter:
Similar to the “Outbound Response Parameter Mapping”, the dictionary field mapping is completed for inbound parameter.
Error Message:
com.newscale.is.core.RoutingException: Routing exception found: Reference Field not retrieved from response <?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Body><FahrenheitToCelsiusResponse xmlns="http://tempuri.org/"><FahrenheitToCelsiusResult>40.5555555555556</FahrenheitToCelsiusResult></FahrenheitToCelsiusResponse></soap:Body></soap:Envelope> caused by: Reference Field not retrieved from response <?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Body><FahrenheitToCelsiusResponse xmlns="http://tempuri.org/"><FahrenheitToCelsiusResult>40.5555555555556</FahrenheitToCelsiusResult></FahrenheitToCelsiusResponse></soap:Body></soap:Envelope> at com.newscale.is.core.MessageRouter.routeMessage(MessageRouter.java:118) at com.newscale.is.core.MessageExecutor.processOutboundMessage(MessageExecutor.java:604) at com.newscale.is.core.MessageExecutor.processMessage(MessageExecutor.java:125) at com.newscale.is.core.QueueListener.handleTextMessage(QueueListener.java:91) at sun.reflect.GeneratedMethodAccessor115.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.camel.component.bean.MethodInfo.invoke(MethodInfo.java:340) at org.apache.camel.component.bean.MethodInfo$1.proceed(MethodInfo.java:237) at org.apache.camel.component.bean.BeanProcessor.process(BeanProcessor.java:168) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:99) at org.apache.camel.component.bean.BeanProcessor.process(BeanProcessor.java:73) at org.apache.camel.impl.ProcessorEndpoint.onExchange(ProcessorEndpoint.java:101) at org.apache.camel.impl.ProcessorEndpoint$1.process(ProcessorEndpoint.java:71) at org.apache.camel.util.AsyncProcessorConverterHelper$ProcessorToAsyncProcessorBridge.process(AsyncProcessorConverterHelper.java:61) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:73) at org.apache.camel.processor.SendProcessor$2.doInAsyncProducer(SendProcessor.java:115) at org.apache.camel.impl.ProducerCache.doInAsyncProducer(ProducerCache.java:285) at org.apache.camel.processor.SendProcessor.process(SendProcessor.java:110) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:73) at org.apache.camel.processor.DelegateAsyncProcessor.processNext(DelegateAsyncProcessor.java:99) at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:90) at org.apache.camel.management.InstrumentationProcessor.process(InstrumentationProcessor.java:71) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:73) at org.apache.camel.processor.DelegateAsyncProcessor.processNext(DelegateAsyncProcessor.java:99) at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:90) at org.apache.camel.processor.interceptor.TraceInterceptor.process(TraceInterceptor.java:91) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:73) at org.apache.camel.processor.RedeliveryErrorHandler.processErrorHandler(RedeliveryErrorHandler.java:322) at org.apache.camel.processor.RedeliveryErrorHandler.process(RedeliveryErrorHandler.java:213) at org.apache.camel.processor.RouteContextProcessor.processNext(RouteContextProcessor.java:45) at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:90) at org.apache.camel.processor.interceptor.DefaultChannel.process(DefaultChannel.java:303) at org.apache.camel.processor.RouteContextProcessor.processNext(RouteContextProcessor.java:45) at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:90) at org.apache.camel.processor.UnitOfWorkProcessor.processAsync(UnitOfWorkProcessor.java:150) at org.apache.camel.processor.UnitOfWorkProcessor.process(UnitOfWorkProcessor.java:117) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:73) at org.apache.camel.processor.DelegateAsyncProcessor.processNext(DelegateAsyncProcessor.java:99) at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:90) at org.apache.camel.management.InstrumentationProcessor.process(InstrumentationProcessor.java:71) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:99) at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:86) at org.apache.camel.component.jms.EndpointMessageListener.onMessage(EndpointMessageListener.java:105) at org.springframework.jms.listener.AbstractMessageListenerContainer.doInvokeListener(AbstractMessageListenerContainer.java:561) at org.springframework.jms.listener.AbstractMessageListenerContainer.invokeListener(AbstractMessageListenerContainer.java:499) at org.springframework.jms.listener.AbstractMessageListenerContainer.doExecuteListener(AbstractMessageListenerContainer.java:467) at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.doReceiveAndExecute(AbstractPollingMessageListenerContainer.java:325) at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.receiveAndExecute(AbstractPollingMessageListenerContainer.java:263) at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.invokeListener(DefaultMessageListenerContainer.java:1059) at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.executeOngoingLoop(DefaultMessageListenerContainer.java:1051) at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.run(DefaultMessageListenerContainer.java:948) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) at java.lang.Thread.run(Thread.java:662) Caused by: com.newscale.is.adk.exceptions.AdapterException: Reference Field not retrieved from response <?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Body><FahrenheitToCelsiusResponse xmlns="http://tempuri.org/"><FahrenheitToCelsiusResult>40.5555555555556</FahrenheitToCelsiusResult></FahrenheitToCelsiusResponse></soap:Body></soap:Envelope> at com.newscale.is.adapter.http.HTTPOutboundAdapter.call(HTTPOutboundAdapter.java:204) at com.newscale.is.adapter.http.HTTPOutboundAdapter.processMessage(HTTPOutboundAdapter.java:147) at com.newscale.is.core.MessageRouter.routeMessage(MessageRouter.java:115) ... 54 more ----ROOT CAUSE---- com.newscale.is.adk.exceptions.AdapterException: Reference Field not retrieved from response <?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Body><FahrenheitToCelsiusResponse xmlns="http://tempuri.org/"><FahrenheitToCelsiusResult>40.5555555555556</FahrenheitToCelsiusResult></FahrenheitToCelsiusResponse></soap:Body></soap:Envelope> at com.newscale.is.adapter.http.HTTPOutboundAdapter.call(HTTPOutboundAdapter.java:204) at com.newscale.is.adapter.http.HTTPOutboundAdapter.processMessage(HTTPOutboundAdapter.java:147) at com.newscale.is.core.MessageRouter.routeMessage(MessageRouter.java:115) at com.newscale.is.core.MessageExecutor.processOutboundMessage(MessageExecutor.java:604) at com.newscale.is.core.MessageExecutor.processMessage(MessageExecutor.java:125) at com.newscale.is.core.QueueListener.handleTextMessage(QueueListener.java:91) at sun.reflect.GeneratedMethodAccessor115.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.camel.component.bean.MethodInfo.invoke(MethodInfo.java:340) at org.apache.camel.component.bean.MethodInfo$1.proceed(MethodInfo.java:237) at org.apache.camel.component.bean.BeanProcessor.process(BeanProcessor.java:168) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:99) at org.apache.camel.component.bean.BeanProcessor.process(BeanProcessor.java:73) at org.apache.camel.impl.ProcessorEndpoint.onExchange(ProcessorEndpoint.java:101) at org.apache.camel.impl.ProcessorEndpoint$1.process(ProcessorEndpoint.java:71) at org.apache.camel.util.AsyncProcessorConverterHelper$ProcessorToAsyncProcessorBridge.process(AsyncProcessorConverterHelper.java:61) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:73) at org.apache.camel.processor.SendProcessor$2.doInAsyncProducer(SendProcessor.java:115) at org.apache.camel.impl.ProducerCache.doInAsyncProducer(ProducerCache.java:285) at org.apache.camel.processor.SendProcessor.process(SendProcessor.java:110) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:73) at org.apache.camel.processor.DelegateAsyncProcessor.processNext(DelegateAsyncProcessor.java:99) at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:90) at org.apache.camel.management.InstrumentationProcessor.process(InstrumentationProcessor.java:71) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:73) at org.apache.camel.processor.DelegateAsyncProcessor.processNext(DelegateAsyncProcessor.java:99) at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:90) at org.apache.camel.processor.interceptor.TraceInterceptor.process(TraceInterceptor.java:91) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:73) at org.apache.camel.processor.RedeliveryErrorHandler.processErrorHandler(RedeliveryErrorHandler.java:322) at org.apache.camel.processor.RedeliveryErrorHandler.process(RedeliveryErrorHandler.java:213) at org.apache.camel.processor.RouteContextProcessor.processNext(RouteContextProcessor.java:45) at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:90) at org.apache.camel.processor.interceptor.DefaultChannel.process(DefaultChannel.java:303) at org.apache.camel.processor.RouteContextProcessor.processNext(RouteContextProcessor.java:45) at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:90) at org.apache.camel.processor.UnitOfWorkProcessor.processAsync(UnitOfWorkProcessor.java:150) at org.apache.camel.processor.UnitOfWorkProcessor.process(UnitOfWorkProcessor.java:117) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:73) at org.apache.camel.processor.DelegateAsyncProcessor.processNext(DelegateAsyncProcessor.java:99) at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:90) at org.apache.camel.management.InstrumentationProcessor.process(InstrumentationProcessor.java:71) at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:99) at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:86) at org.apache.camel.component.jms.EndpointMessageListener.onMessage(EndpointMessageListener.java:105) at org.springframework.jms.listener.AbstractMessageListenerContainer.doInvokeListener(AbstractMessageListenerContainer.java:561) at org.springframework.jms.listener.AbstractMessageListenerContainer.invokeListener(AbstractMessageListenerContainer.java:499) at org.springframework.jms.listener.AbstractMessageListenerContainer.doExecuteListener(AbstractMessageListenerContainer.java:467) at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.doReceiveAndExecute(AbstractPollingMessageListenerContainer.java:325) at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.receiveAndExecute(AbstractPollingMessageListenerContainer.java:263) at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.invokeListener(DefaultMessageListenerContainer.java:1059) at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.executeOngoingLoop(DefaultMessageListenerContainer.java:1051) at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.run(DefaultMessageListenerContainer.java:948) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) at java.lang.Thread.run(Thread.java:662)
12-01-2013 11:38 PM
This issue was resolved for me. They key fix is that the parameter name and the field name in dictionary should be same After having this change, I didn't get any issue and the result got inserted in the field.
