11-17-2011 06:01 PM
HTTP adapter
anyone use it? I was able to set up the outbound process. Inbound keep failing with blank XML message. Anybode else that succesfully uses it?
btw, channel-id (in documentation) is no thte proper variable to use in the URL it should be channelId
11-17-2011 06:01 PM
Tylor, thanks! I just wanted to make sure its functional. I rewrote the HTTP post to be content text/xml and it worked after a while ....
11-17-2011 06:01 PM
We're successfully using the HTTP adapter to call a web service. The the XML response from the web service call correctly gets input as the inbound message.
11-17-2011 06:01 PM
Menke
10:10am, May 5
How did you structure your HTTP Post to get this to work?
