Installing RequestCenter on a laptop with JBOS
I am attempting to install RequestCenter build 1961  (2006.07) and I am getting an error that no valid webserver was found.  I thought that by selecting JBOS that the webserver was installed on the system automatically without the need of a previous installation.
Please advise...
Thank you
Daniel
Safeway Inc.
Everyone's tags (1)
Hi Daniel,
You also need to install/enable Microsoft IIS. Have you done this yet?
Daniel,
your company policy might prevent you from running IIS on your lappy.
Running the installer will stop the Default WebSite under IIS, if you do not finish up the installer then you need to make sure the default website is running before reattempting it.
If port 80 does not work, please try port 8080 or 8088
also make sure that web, app and db server point to localhost .....
155
