Community Member
Is there a way to update an external dictionary for services without migrating the services
Is there a way to update a common external dictionary used by many services without migrating each and every service that uses the dictionary.  I have updated the table in the database and the external dictionary in our Development Environment. The external dictionary is used by many services. When I migrate the changed service to TEST/STAGE/PROD environments (NOTE: the table has been updated in the TEST/STAGE/PROD Databases), only the changed service is having the external dictionary updated. All other services that use the same external dictionary are NOT updated. I have the following questions
  • Is it possible to migrate dictionaries so that all the services which are using that dictionary are updated?
  • If the first one is not possible, Is there any other way to update the external dictionary without migrating all the services that use dictionary?
Everyone's tags (1)
156
