Keywords & categories go missing during export & import
Christine Khor
I noticed that when exporting & importing a service, the keywords & categories are kept in the imported service, but disappeared from the exported one. Is that how it should work, or is there an error?
Thanks / Christine
Christine Khor
Hi, I wonder if anybody else has experienced this? Is it a general issue or is it only us - probably due to erroneous setup? I sincerely  someone, or at least newScale is able to give me an explanation.
I use the export & import functionality because it saves time not having to enter the same information or do the same setup twice. But then you have to spend time re-entering all the keywords & categories, which is really a waste of time and doesn't make sense. Additionally, unless you realise & do the necessary, all the services from which you 'copied from' are left without keywords & categories.
Thanks.
Carol Josefek
Hi Christine, You're not alone - we experience this as well.
Christine Khor
Then maybe it's a general error in the system that needs to be resolved by newScale.
