Query Studio (2006.0.8)
We have a report that was built using Query Studio that is producing 2 different views.  When we run the report by using the Query Studio option from the reports menu, it produces an incomplete set of columns/rows.  When we run the same report using the run option on the reports menu, it produces a completely different set of columns/rows.  In the current situation, the report from the run option is what we want.  How do we make it work correctly in Query Studio.
Everyone's tags (1)
1 REPLY
Hi Elizabeth,
In Query Studio, do you see if there is a horizontal and vertical scrollbar inside a frame?  The report output in Query Studio is displayed in a frame.  Please double check to make sure you can scroll down or to the right to see other missing columns or rows that do not fit the screen.
Peter
154
