Community Member
Reportable Dictionary Best Practices
We are looking to begin making dictionaries reportable and I am hoping to collect feedback on some best practices for this initiative. Should we make all dictionaries reportable? What are the ramifications of making a dictionary reportable? What is the best way to determine which dictionaries should be reportable and which dictionaries should not be reportable? We have consulted the ServiceAnalytics guide and are looking for more information and real world experiences. Thank you.
Everyone's tags (1)
Community Member
David,
Your response was very helpful. Thank you.
-Chad
Community Member
This depends on the version of RC that you are on.  There are limitations on the 2006 version.  We have 2006.0.6 installed and can not make more then 5-6 dictionaries reportable before causing errors in the datamart build scripts.  SongBac should be able to post what versi
Sorry to be a late comer here.  In general, we do recommend that you start out slow and only mark the dicitonaries you want to report against reportable as David pointed out.  You can always add mark additional dictionaries reportable later on.
I'd definitely recommend upgrading to the latest major version.  You can go to 2007 if you prefer not to go to 2008 yet.  On 2006, you should at least move to the post 2006.0.7 versions.  We have stabilized the reporting functionality on the 2006 branch too,
145
