Community Member
SLA/Volume Reports
SLA/Volume Reports
2006.0.8
I have a customer that wants to run a report that shows a total of Volume and SLA by month per service.  They only want totals to come up automatically that they can chart the progress.  They don't want to run it every month then input the totals in a separate file. I can't find it via standard reports.  Can this be done via custom?  Make sense?
For instance:
Month              Volume            SLA
January 08        20                     80%
February 08       15                     100%
March 08           25                     75%
April 08             30                     100%
Everyone's tags (1)
SLA/Volume Reports
Like Ed said, you should be able to build this report in newScale Advanced Reporting.  You should be able to even generate the chart as part of the report .
Community Member
SLA/Volume Reports
You could build this as a custom report. However, have you considered using the On-Time % by Service Report? You could run this for just the desired services and date ranges, output to excel, then delete any of the task detail you don't want.
Community Member
SLA/Volume Reports
Ed/Song,
Thank you for your replies.  We did look at the Report Ed suggested, but they don't wont the "clean up".
Song, would you set this up?
171
