Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
SpyLogger
SpyLogger
What is SpyLogger used for?
Original Exception:
Error Message: SRVE0207E: Uncaught initialization exception thrown by servlet
Error Code: 500
Target Servlet: action
Error Stack:
java.lang.NoClassDefFoundError: com/newscale/jdbcspy/SpyLogger
Error Page Exception:
Error Message: com/newscale/jdbcspy/SpyLogger
Error Code: 0
Target Servlet: null
Error Stack:
     at com.newscale.jdbcx.base.BaseDataSource.setLogWriter(Unknown Source)
Everyone's tags (1)
SpyLogger
Hi Emir, I'm investigating your question and will post an answer soon.
SpyLogger
Thanks Enrico.
The issue is when you have Robust debugging (*=finest) enabled via WebSphere. Its trying to log the JDBC calls and it fails calling the class resulting in full outage of the system.
SpyLogger
Emir, from our Engineering team:
"DataDirect Spy is a special debugging library for the DataDirect drivers. It can record all driver interactions at a very fine level. It is not enabled by default [and is not currently used by RequestCenter].
SpyLogger
Is there a requirement to set debugging to *=finest? Does the next higher level of debugging detail meet your needs?
425
