4240 memory question
peter.williams
I have a 4240 IPS unit and it is using 1371 out of 1893 and only has 522 left and it is climbing. Is this normal and if it is not how do I clear the memory so it is not using so much memory?
mhellman
Level 7
Level 7
They will tend to use all available memory. Unless you start swapping to disk, don't worry about it.
mhellman
Level 7
Level 7
Thank you for your reply
