4260 Sensors connected to Active/ Active firewalls
I have the following scenario:
We have two edge firewalls with Active/ Active setup connected directly to two core switches. New two IPS sensor s4260 are required to be connected inline between the firewalls and core switches. What is the best practice design for such a scenario? Does the below diagram work fine in this case or another design is applicable?
Re: 4260 Sensors connected to Active/ Active firewalls
You need to give more details regarding yoru design.
Are you using Inline Interface Pair or VLAN Pair?
What is the expected throughput of the Network?
Are these WAN firewalls or Internet?
Are there any server farms?
Farrukh
we will use Vlan Pair
100 mb/s
wan firewall (FWSM)
conected 6500
440
