AIP-SSM-10 auto update issue
Hi! experts
I using AIP-SSM-10 module on ASA 5540
But it is not working auto update signature.
So I `m going to attach " show statistics host" result.
Can you tell me some help?
Thanks in advance
Auto Update Statistics
lastDirectoryReadAttempt = 07:34:50 UTC Tue Oct 20 2009
= Read directory: https://198.133.219.25/cgi-bin/ida/locator/locator.pl
= Error: AutoUpdate exception: HTTP connection failed [1,0]
lastDownloadAttempt = N/A
lastInstallAttempt = N/A
nextAttempt = 04:00:00 UTC Wed Oct 21 2009
Re: AIP-SSM-10 auto update issue
Does your management interface ip-address have an access to Internet directly via NAT or using proxy?
Sure
It is possible connect to internet.
It is clear that mgmt ifaces are able to connect to the Internet but if they may connect to inet via proxy you must configure proxy-server.
Gold
To test https connectivity, you can create a service account on your sensor and try to telnet to 198.133.219.25 port 443
623
