AIP SSM-10 configuration on ASA 5520
Hi All,
I need to configure IPS module on ASA 5520.
I have assigned ip address to the ips module but not able to access it from the asdm.
Re: AIP SSM-10 configuration on ASA 5520
Just open a web-browser and open the AIP-SSM.
https://
I hope you have connected the Ethernet interface to the network and added your admin machine to the list of permitted IPs on the AIP-SSM.
Farrukh
http://www.cisco.com/en/US/docs/security/ips/6.1/installation/guide/hw_logging_in.html#wp1039632
start at the ASA firewall command line.
session into the IPS module.
config a couple of basics from IPS command line
connect the IPS module ethernet interface to your network
access the IPS with the assigned IP address using either your browser, SSH or telnet.
thanks ..
now i able to login to the IPS module throgh ASDM.If any separate license is required for IPS module?
Yes to be able to use the signature updates. Otherwise the sensor is fully functional with the signature set shipped with the software version you are on.
You need the "Cisco Services for IPS" licesne for your AIP-SSM to get signature updates from the internet. However you can do software upgrades when they are released and keep upgrading your AIP to the signature release present in the upgrade. This is not recommended tough.
Farrukh
From the IPS GUI, you can go to the licensing section (look on left side). You can have the sensor go to Cisco to check on license status or you can manually load the license.
Also note the serial number of the IPS. You can see this from the GUI in the license section or in the monitor section (system information).
thanks all,
I have registerd the IPS serial number with cisco and got the license.
One thing I want know where can i get the signature update for IPS?
dileep
You can downloaded them from here:
http://www.cisco.com/cgi-bin/tablebuild.pl/ips6-sigup
Farrukh
1356
