Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
AIP-SSM-10 management port
Why is it 1G ? what's purpose ?
1 REPLY
Community Member
Re: AIP-SSM-10 management port
No pun intended but it's for Management. Why is it 1 gig? Why not?
Once the module is installed and configured this is the port you will connect to through ADSM. Do a "session 1" command on the ASA to access the SSM, type setup, and follow the prompts. Once you give the module an IP address and reload it you will be able to access the module via ADSM.
189
