Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
AIP SSM-20 Startup Wizard Problem
I am getting the Warning Window "The Startup Wizard will not able to allocate ASA traffic to this sensor for inspection. ASDM must be upgraded to a newer version before you can allocate traffic using this wizard." everytime I launch Startup Wizard for IPS from ASDM. As a result it is not letting go further than Basic Sensor Setup. I currently have ASA 5510 security appliance with ASA-SSM-20. ASA version is 8.2(1). ASDM Version is 6.2(3). IPS Version is 7.0(2)E3 with Signature Version 447.
Any ideas will be greatly appreciated to resolve this issue.
Community Member
Re: AIP SSM-20 Startup Wizard Problem
May be this version of ASDM doesn't understand IPS 7.0
Use IPS Manager Express 7.0 to do it.
Community Member
I already tried IME and Iam getting this Warning Window;
"The Startup Wizard will not be able to allocate ASA traffic to this sensor for inspection.
This wizard can only allocate traffic on the ASA when it is started from an ASDM session.
To allocate ASA traffic from this wizard, start ASDM, then select Configure, IPS, Launch Startup Wizard."
It is giving me no choice but ASDM!
561
