Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
AIP-SSM not gettint outside traffic
Hi all. I have a AIP-ssm 10 and I created two class-map.. one for inside and one for the outside.. and applyed like the following.
policy-map global_policy
class inspection_default
  inspect ftp
  inspect icmp
  inspect pptp
policy-map outside-policy
class outside-class
  ips inline fail-open
policy-map inside-policy
class inside-class
I also tryed with the global policy but the result was the same... I don't get nothing in the alerts... when i receive something... is from the inside network..
But from outside.. i have nothing... and I tryed to make some scans.. but.. nothing happend...
Here is the configuration of the IDS....
Could someone help me?
I Also tryed this solution... https://supportforums.cisco.com/message/1323736#1323736 but... has no effect....
Thanks in advance...
Fabio
! Current configuration last modified Thu Jan 28 18:05:49 2010
! Version 7.0(2)
! Host:
!     Realm Keys          key1.0
! Signature Definition:
!     Signature Update    S458.0   2010-01-04
!     Virus Update        V1.4     2007-03-02
service interface
exit
service authentication
exit
service event-action-rules rules0
exit
service host
network-settings
host-ip 192.168.100.201/24,192.168.100.1
host-name IPS02
telnet-option disabled
access-list 10.10.110.0/24
access-list 172.27.1.0/24
access-list 172.27.20.0/24
dns-primary-server enabled
address 172.27.1.7
exit
dns-secondary-server enabled
address 172.27.1.3
exit
dns-tertiary-server enabled
address 172.27.1.8
exit
exit
time-zone-settings
offset -180
standard-time-zone-name GMT-03:00
exit
ntp-option enabled-ntp-unauthenticated
ntp-server 172.27.1.7
exit
exit
service logger
exit
service network-access
exit
service notification
exit
service signature-definition sig0
exit
service ssh-known-hosts
exit
service trusted-certificates
exit
service web-server
exit
service anomaly-detection ad0
exit
service external-product-interface
exit
service health-monitor
exit
service global-correlation
exit
service analysis-engine
virtual-sensor vs0
anomaly-detection
operational-mode detect
exit
physical-interface GigabitEthernet0/1
exit
exit
1 REPLY
Re: AIP-SSM not gettint outside traffic
Are you policy-map applied with a "service-policy"? Please make sure they do.
What traffic is the aip class-map matching? Is it matching all traffic? Please make sure it does.
PK
425
