02-09-2010 09:38 AM - edited 03-10-2019 04:53 AM
Guys,
I need to create my KB because the current is very very old ( 09:59:59 GMT-06:00 Tue Sep 22 2009 ) When I try to save it manually with the command
anomaly-detection vs0 save MYKB I get an error that says: Attack in progress
I need to create a new KB and load it because the Rotate methot is not working since the last KB is very old. I thisk it's not working because there is an attack ALWAYS.
Can I save a load a KB file manually even if there is an attack in progress?
If not, How can I fix my problem
DiegoCR CCSP
Solved! Go to Solution.
02-09-2010 10:52 AM
Hi Diego
You can fix this by:
Br
Johan Kellerman
02-09-2010 10:52 AM
Hi Diego
Br
Johan Kellerman
02-09-2010 11:14 AM
Thank you very much. I just release that I'm seeing unidirectional traffic so I will turn AD off.
