Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 5515-X IPS Edition Question
Is the Cisco ASA 5515-X IPS Edition meant to replace an Internet edge firewall or to be installed before the edge firewall to provide IPS services?
VIP Purple
Re: ASA 5515-X IPS Edition Question
With that device you get the complete functionality of the ASA with the addition of IPS. So if your internet-edge should be build with one firewall, which is quite common in medium-sized business, then it will replace the old firewall.
VIP Purple
But if your security-team wants to keep the old firewall, you can disable all firewalling on the IPS-Edition ASA and use it as a pure IPS-device behind your existing edge-firewall. Both scenarios are possible.
678
