ASA 5525 IPS
CSCO11209280
                   I have a asa 5525 and the license with IPS ,but i dont know How usede the IPS issue.anyone can tell me?
14 Replies 14
sawgupta
Your question is not very clear. Are you unable to connect to IPS ?
From ASA, you can simply issue "session ips" to connect to IPS and configure.
Any specific problem that you are facing ?
Sawan Gupta
Thanks & Regards, Sawan Gupta
yes unable to connect to IPS
how can i use the IPS
This guide should help you out:
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/modules_ips.html
Let me know what is your exact requirement.
Sawan Gupta
can't input “ session 1” in the ASA,
i don't know how active it
Please use "session ips". I updated my answer above.
http://www.cisco.com/en/US/docs/security/ips/7.1/installation/guide/hw_logging_in.html#wp1072132
Sawan Gupta
Command is "session ips" and you can check the module state using "show module ips" command.
when "session ips "  it note:can't sent message to module
You need license to be able to use IPS, can you please check if IPS module is enabled on your box.
Please issue "show module ips" command and check the License Status -
# show module ips
Mod License Name   License Status  Time Remaining
ips IPS Module     Enabled         perpetual
OK ,thank you for your help.
next monday,i will try again.
You would need to re-image IPS
http://www.cisco.com/en/US/docs/security/ips/7.1/configuration/guide/idm/idm_system_images.html#wpxref15759
Sawan Gupta
thank you very much
I re-image ips and "show module" and "session IPS"
ciscoasa# show module
Mod Card Type                                    Model              Serial No.
  0 ASA 5525-X with SW, 8 GE Data, 1 GE Mgmt, AC ASA5525            FCH1623704D
ips ASA 5525-X IPS Security Services Processor   ASA5525-IPS        FCH1623704D
Mod MAC Address Range                 Hw Version   Fw Version   Sw Version
  0 a493.4caa.50b3 to a493.4caa.50bc  1.0          2.1(9)8      8.6(1)
ips a493.4caa.50b1 to a493.4caa.50b1  N/A          N/A          7.1(4)E4
Mod SSM Application Name           Status           SSM Application Version
ips IPS                            Up               7.1(4)E4
Mod Status             Data Plane Status     Compatibility
  0 Up Sys             Not Applicable
ips Up                 Up
when loggin IPS display
***LICENSE NOTICE***
There is no license key installed on this IPS platform.
The system will continue to operate with the currently installed
signature set.  A valid license must be obtained in order to apply
signature updates.  Please go to http://www.cisco.com/go/license
to obtain a new license or install a license.
why no license!!
IPS will continue to work perfectly fine; however for Signature updates, you would require a license.
http://www.cisco.com/en/US/docs/security/asa/asa84/asdm64/configuration_guide/modules_ips.html#wp1104578
Sawan Gupta
Hi guys please how do i install the Lincence of Cisco IPS trial- version on my ASA .
