ASA 5525-X IPS AutoUpdate Fail
I am experiencing issues with the Auto Update feature for signature definitions for the 5525-X IPS module. I am using Cisco-Server auto-update with a proxy server (I am running the latest Engine Version).
# sh ver
Application Partition:
Cisco Intrusion Prevention System, Version 7.2(1)E4
The autoupgrade settings are as follows:
(config-hos-aut)# sh settings
   auto-upgrade
      cisco-server
         enabled
            schedule-option
               periodic-schedule
                  start-time: 15:18:00 default: 00:00:00
                  interval: 1 hours default: 24
            user-name: radu.ioncu
            password: <hidden>
            cisco-url: https://72.163.4.161//cgi-bin/front.x/ida/locator/locator.pl default: https://www.cisco.com//cgi-bin/front.x/ida/locator/locator.pl
      user-server
         disabled
(config-hos-aut)#
The proxy server is correctly configured and allowing traffic to any destination, as global correlation is working properly. When initiating an auto upgrade, the logs look like this:
evStatus: eventId=6822849343323 vendor=Cisco
  originator:
    hostId:
    appName: mainApp
    appInstanceId: 1587
  time: 2013/08/08 13:57:45 2013/08/08 16:57:45 EEST
  autoUpgradeServerCheck:
    uri: https://radu.ioncu@72.163.7.60//swc/esd/02/273556262/guest/
    packageFileName: IPS-sig-S732-req-E4.pkg
    result: status=true
vStatus: eventId=6822849343327 vendor=Cisco
  originator:
    hostId:
    appName: mainApp
    appInstanceId: 1587
  time: 2013/08/08 14:00:54 2013/08/08 17:00:54 EEST
  downloadUpgradeFile:
    uri: https://radu.ioncu@72.163.7.60//swc/esd/02/273556262/guest/IPS-sig-S732-req-E4.pkg
    result: status=false autoUpdate successfully selected a package (https://radu.ioncu@72.163.7.60//swc/esd/02/273556262/guest/IPS-sig-S732-req-E4.pkg) from the cisco.com locator service, however, package download failed: HTTP connection failed
So the IPS can succesfully connect, find the download URL, but the download misteriously fails. I can download the file from the above URL from a PC with the same Proxy set.
Did anyone encounter this problem and do you know any solutions?
Thanks!
1 ACCEPTED SOLUTION
Solved by TAC - actually not solved. This behaviour is caused by a bug - CSCui05041 - AutoUpdate Proxy Not Working. Will be solved in a future release.
1 REPLY
1442
