11-20-2010 02:12 PM - edited 03-10-2019 05:11 AM
Folks,
Does the AIP-SSM replicate the configuration to other AIP-SSM into ASA/Standby?
I mean, when I change the configuration over the Active AIP/SSM, will that change make replicated to other AIP-SSM?
thanks
Solved! Go to Solution.
11-20-2010 02:29 PM
Yes, unfortunately all the IPS is the same. Configuration doesn't automatically replicate from 1 unit to the other.
Please kindly mark the post as answered if you have no further question. Thanks..
11-20-2010 02:18 PM
No, the configuration on tohe AIP-SSM module is independant on both the Active/Standby ASA. You would need to manually configure both the
AIP-SSM module independently, and also with different ip addresses assigned to them.
Hope that answers your question.
11-20-2010 02:23 PM
Hi Jennifer,
thanks for your reply.
Then, the AIP-SSM have the same behavior about IDSM-2, we are buying two modules of the IDSM-2 and I was looking for how to replicate the configurations and I saw that there is no way to do this.
thanks a lot
11-20-2010 02:29 PM
