08-03-2006 04:56 AM - edited 03-10-2019 03:08 AM
I had a consultant come in and install the IPS on my firewall, well he forget the login password for the SSM-10 IPS and now I can't get into it. I have tried all the hw module 1 restart, reload, config options and have removed the card and looked for a hard reset button but nothing has worked. How do I get into the IPS so I can reset the password?
Rich Weber
08-03-2006 08:11 AM
The only way is to do a recovery, complete instructions are at:
In a nutshell:
1) cable the ssm module to a tftp server (can be via a switch or whatever)
2) issue the hw-module command to do a configure (enter params as prompted)
3) issue the hw-module command to reboot
Note that your tftp server needs to be able to handle files >16MB
HTH - plz rate if it does
Andrew.
08-03-2006 10:23 AM
Already tried all that, did not work. Am now trying an image upgrade as that sets all passwords to Cisco, Cisco. Thanks though.
Rich
08-04-2006 01:35 AM
The image upgrade is the same process if you don't have the password.....
Andrew.
